05-26-2012, 09:49 AM | #1 |
lets put together a driveshaft length chart
lets put our heads together to make a chart or list of the driveshaft lengths for the different truck/ tranny configs, i am mostly interested in 2wd swb 700r4 right now, but i think it would be good to have a refence chart for all of us.
thanks Wade |
05-26-2012, 09:59 AM | #2 |
Re: lets put together a driveshaft length chart
74 swb TH350 short tail 6in 12bolt rear end
59 1/2in from center u-joint to center u-joint 84 swb 700R4 10bolt rear end 55 1/2in from center u-joint to center u-joint Posted via Mobile Device
John 82 Chevy Silverado 350ci/TH350 |
12-10-2013, 09:59 PM | #3 |
Was this chart ever made? I'm building a 49 3100 and put a Vortec 350 in it with a 700R4 tranny and a GM10 bolt posi from a 78 Z28. I would like to find a stock pickup driveshaft that I could cut down instead of having a custom one made. Anyway, just checking!
12-11-2013, 08:12 AM | #4 |
For some reason it never did. Mustve just been bad timing. And im guilty too. There is a stock driveshaft I was able to use for my gen1 355/gen 1 t56 combo in my 86 2wd short bed with an 8.5 10 bolt. But its tucked in for the winter and I forget what it came from... im pretty sure it was a 66 Pontiac car. Remind me this spring to check which one it was its written on the driveshaft itself but its packed tight in my garage and -4* today. Brrrr
12-11-2013, 09:31 AM | #5 |
Here is a little info I learned going from a 700r4 with np208 transfer case to TH400 with np208 transfer case. I assumed the drive shafts would be different, but it turned out they were the same length and I was able to use the old ones.
12-11-2013, 12:42 PM | #6 |
TH400 with Gear Vendor's O/D to 12bolt rearend. 45.5" driveline length, measured center to center of U-Joint caps.
Welcome to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=574370 |
11-12-2014, 04:53 PM | #7 |
I'll dig this one back up. Does anyone know if the u joints are the same for the th350/4l60e yokes and the th400?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
11-12-2014, 05:06 PM | #8 | |
I asked him for the chart he referred to when he released these parts for production. He said he would find it and get it over to me. I never heard back from him.... K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-13-2014, 05:00 AM | #9 |
Does anyone know the length of driveshaft I would need to put a Saginaw 4 speed from a 78 Camaro in my SWB 84 c10 with the factory 10 bolt? Locally it would cost me $300 to $400 to have a custom one built. I am gonna try and find one from another vehicle that works with no mods. None of the shops in my area that I know of shorten them either due to liability issues.
11-13-2014, 10:23 AM | #10 | |
Measure the two transmissions and subtract the difference.
11-13-2014, 10:29 AM | #11 | |
