05-26-2012, 03:15 PM | #1 |
t56 clutch hose swap help
ok all, I am swapping a T56 into my truck and am missing the correct length of clutch hose from the master to the slave. I know the swap has been done but the search didnt turn up the answer.
I need an off the shelf at the parts store solution it seems like there is not one. thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-28-2012, 02:22 PM | #2 |
Re: t56 clutch hose swap help
is it an ls1 or lt1 sourced trans? if youre using the factory lt1 components on a 1pc rear main engine, the master/slave/hoses are one-piece and available from a dealer for like 225 bucks i think... dont quote me. if its ls1, i got nothin... lol. hope i helped even a little bit...
05-29-2012, 09:05 AM | #3 |
Thanks for the reply it is an ls1 tranny. Yea I found I can buy the master cylinder and hose assembly from GM but I already had a master cylinder fit in mine. So I will probably end up buying that from them so I can get it running. I knew others had done the swap and didnt find what they used. I was in a bit of a time crunch trying to get it over the weekend so I can look a little more today.
I have a place local that makes hoses so I may check with them but I am guessing the fittings are special. I should have it going before the power tour...
05-29-2012, 12:46 PM | #4 |
Speedway has an LS1 style hose with the required "quick disconnect" fitting. You'll also need a Tilton 7/8 master cylinder mounted to your firewall to actuate the hydraulic throwout bearing. Some fabrication will be required, but the result will be a smooth shifting setup than is leak free and reliable.
http://www.speedwaymotors.com/T56-Hy...nch,39869.html Thats just one example, a 30" length of hose. Speedway sells several lengths, search the site and measure an estimate of what you'd need. |
06-09-2012, 07:14 PM | #5 |
What master are you using? I used an S10 master and S10 line. Both can be bought at the auto parts store for about 100 total
69 C10 SWB LY6 T56 70 Chevelle SS 396 4spd |
06-11-2012, 09:59 AM | #6 |
Thanks for that, I am using an s10 master cylinder but they didnt seem to have the hose or it may have had to be ordered I dont remember. I ended up getting mine spliced and lengthened as I needed it last minitue. I got it completed and hit the road and made the last half of the power tour.
06-11-2012, 10:03 AM | #7 |
LOL, Dave I didn't recognize your avatar for some reason. I'm the guy with the primered C10. Glad you got it fixed!
I used Dorman p/n 628216 for the house
06-11-2012, 10:17 AM | #8 |
oh yea I didnt put it all together either. It was close for me and my son on taking it but in the end it all came together.
