Old 05-26-2012, 10:11 PM   #1
bakerboys
bakerboys's Avatar
starter dragging when hot
I changed my heads to lower my compression to be more street friendly
Now I cant get my timing right Or mayby its right
What happens is when the engine is warm it is hard to start like
ungh ungh ungh ungh ungh
Dragging when cold boom starts right up
I retarded the timing thinking i had it to high but now it feels a little weak
it is set to about 22° at tdc at 2000 rpm and i have the stiff springs on distributer
any help would be great If i set timing to say 30° at tdc then it wont start So i think it is to high but it may just be starter idk
355 roller 9.5 to 1 comp.... with headers thanks fellows
bakerboys is offline   Reply With Quote
Old 05-27-2012, 11:08 AM   #2
von guido
von guido's Avatar
Re: starter dragging when hot
i have problems with heat soak..i put a thermal blanket on the starter and worked great
officer,we weren't racing.. he was merely pacing me.
von guido is offline   Reply With Quote
Old 05-27-2012, 12:16 PM   #3
tazman87
tazman87's Avatar
wrap your headers. and/or heat shield. headers will kill starters
tazman87 is offline   Reply With Quote
Old 05-27-2012, 12:18 PM   #4
bakerboys
bakerboys's Avatar
what should i set my timing at idle and say 2500 rpm should it be at 10° at idle and like 32° at 2500
with vac advanced pluged off
