Old 05-27-2012, 10:45 AM   #1
cheford
Exhaust routing
I was wondering if any of you have run your exhaust through the stock crossmember that the trailing arms attach to. I'm going to be running 2 1/2 " pipes and was thinking of running it through this crossmember. If I cut a big enough opening to do this is the crossmember strong enough or will I need to box it? If any of you have done this could you share a picture or direct me to someone who has done it, please and thanks.
John
cheford is offline   Reply With Quote
Old 05-27-2012, 03:31 PM   #2
6772owner
Gearhead
6772owner's Avatar
Re: Exhaust routing
Quite a few members have done this, they usually use heavy wall round pipe welded to the crossmember to create the round holes for exhaust. You can also buy crossmembers already set up to do this, I prefer the one from Early Classic Enterprises or Porterbuilt (depending on your direction)
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 05-29-2012, 12:58 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Exhaust routing
Check out my build thread (linked below). I cut holes with no reinforcement- been running this way for years with no issues...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-29-2012, 10:43 AM   #4
outlawz916
Re: Exhaust routing
hmm that looks quite tempting to just cut holes without reinforcing, has anyone else done it without problems?
outlawz916 is offline   Reply With Quote
Old 06-05-2012, 10:06 AM   #5
Portmod7
Portmod7's Avatar
Re: Exhaust routing
Here is what mine looks like. No reinforcement. Neither Early Classic nor CPP reinforces theirs (although cpp's is built a little different), and to me it didn't really seem like I was getting rid of enough to worry about it. These are 3" holes to run 2.5" exhaust through.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 06-17-2012, 12:26 AM   #6
wagonslayer
Re: Exhaust routing
just did this a few days ago.
wagonslayer is offline   Reply With Quote
Old 07-26-2012, 10:41 PM   #7
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Exhaust routing
Wow. I was just thinking about this. It was recommended that I not cut the rear crossmember. Now that I see this it really makes me wonder. I may try this.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
