Old 05-27-2012, 02:57 PM   #1
SunSoaked
SunSoaked's Avatar
T Case Bracket different 205 vs rockwell
Just discovered my NP205 is actually a rockwell. I plan on swapping in a 205 but the question is:
Is this a bolt in swap or am I gonna need to change x-member and/or braces to accomadate the 205?
SunSoaked is offline   Reply With Quote
Old 05-27-2012, 04:40 PM   #2
vectorit
What?
vectorit's Avatar
Re: T Case Bracket different 205 vs rockwell
Pretty sure there is a difference in the width of the adapter between the trans and the Tcase, the 205 set up I think will cause you to relocate the cross member and modify the drive shafts?
Sure someone more experienced in this will chime in eventually.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-27-2012, 04:50 PM   #3
msgross
msgross's Avatar
I "think" that the crossmember is the same but you will need to find a NP205 with the trans adapter attached. Driveshafts are also different. Holes in the floor hump are different as well.
Why change if it works?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-27-2012, 10:58 PM   #4
odog
odog's Avatar
I agree, if the rockwell works, why go through the trouble of changing. I was going to change to a 205, but it wasnt worth the hassle, I ended up staying with the 221, its a good tcase, just hard to find parts for. My suggestion is run it til it pukes then do a swap.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 05-31-2012, 05:27 PM   #5
1969K10
1969K10's Avatar
You will need a new/different cross member, and to shorten your rear drive shaft. The front one might be OK, I had both fronts when I made the change, and don't remember which I used.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
