Old 05-27-2012, 09:05 PM   #1
corvettejim1968
corvettejim1968's Avatar
small or big hump and tranny question
do i have a small or big hump 1965 c10 230 strait six born with a powerglide now has a 350TH. and do you think a 4L85E tranny will fit?
also does anybody know what the large spring is for? i know the small one is for my jack. thank you
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 05-27-2012, 09:17 PM   #2
rossboss
rossboss's Avatar
Re: small or big hump and tranny question
I believe the large spring holds the lug wrench and jack handle down.
rossboss is offline   Reply With Quote
Old 05-27-2012, 09:18 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Can't help with the floor question, but the long spring is for retaining the jack handle and lug wrench. Posts #4 & 13 include diagrams showing the layout:
http://67-72chevytrucks.com/vboard/s...t=factory+jack
Just read you question again - you definitely have the small hump. I just don't know if the 4L85E trans will fit. Here is a picture of a high hump. The pan is almost square in the center, rises up in front of the seat, and is always removable:
The low hump drops in front of the seat, may be removable or may be a permanent part of the floor. From all the threads I’ve read on this topic, they are not directly interchangeable, however a high hump can be added to a low hump truck if the portion from the high hump donor truck in front of the removable pan is also cut out and welded into the low hump cab.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-27-2012, 09:19 PM   #4
CRGRS 66
CRGRS 66's Avatar
That looks like a small hump to me, the big humps are BIG, usually 4x4's. The spring I believe is the hold down for the factory jack, not 100% certain of that, but that is my guess.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-27-2012, 09:19 PM   #5
CRGRS 66
CRGRS 66's Avatar
If you dig around on here you will see some big humps
Craigerrr
Old 05-27-2012, 09:26 PM   #6
rideblue00
rideblue00's Avatar
CRGRS66 beat me to it, lol. Yeah the big hump you would know if you have it. The hump you have under your seat there...its the same on all trucks. Its the part of the floor thats in front of that. A 4 speed truck floor, is way taller between the firewall and the seat. Powerglide and 3 speed trucks have your floor. The 66 year had the turbo 400 availible and it also has the same floor as yours. I dont have a pic handy. But i have a big hump with a 4 speed SM420 trans. 4 speed floors are also removable. There is a legend out there about the early trucks that had a removable small hump, but i havent seen pics of it. Im not sure on the fit of the newer trans, but the 700r4 supposedly just bumps the floor pan seam that runs side to side, like where your feet go, and some guys just peen it over near where it touches.
rideblue00 is offline   Reply With Quote
Old 05-27-2012, 09:27 PM   #7
ABX131
ABX131's Avatar
You have a small hump. The large hump will line up flush to that rolled seam you have near the edge and extend about 4 inches past the end of your existing floor cover. If you find someone parting out a truck with a large hump, make sure you get the 2nd piece that is spot welded to the tranny tunnel. This is needed or you will have a gap between the end of the hump and the firewall.
ABX131 is offline   Reply With Quote
Old 05-27-2012, 09:32 PM   #8
rideblue00
rideblue00's Avatar
Good call ABX131, i forgot to mention that.
Old 05-28-2012, 07:36 PM   #9
rideblue00
rideblue00's Avatar
Heres a high hump. This is from a fellow member(rossboss). I hope he doesnt mind.
Old 05-29-2012, 12:09 PM   #10
KVB
Will a 700R4 fit under the low hump?
KVB is offline   Reply With Quote
Old 05-29-2012, 06:35 PM   #11
gimmy 64
had a 350 now 2004r low hump and both fit fine. no altering at all
gimmy 64 is offline   Reply With Quote
Old 05-29-2012, 06:44 PM   #12
rideblue00
rideblue00's Avatar
I heard that the low hump will just touch on the 700R4 on the floorpan seam where it connects to the firewall(sidetoside seam) .
Old 05-29-2012, 08:31 PM   #13
sigshooter
sigshooter's Avatar
I have only seen the removeable LOW hump in 1963 trucks.... I pulled one a few weeks back for one of my trucks out of the scrap yard I work in..... There is one in a 63 at Cagles Salvage in Muskogee Oklahoma also..... A friend of mine has one in his 63 parts truck, that is the only three I personally know of left around here
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 05-29-2012, 08:52 PM   #14
rideblue00
rideblue00's Avatar
If you get time, post a picture. Either of the cab floor or the hump itself. Ive never seen one.
Old 05-29-2012, 09:58 PM   #15
cru_zn_29
cru_zn_29's Avatar
I have a small hump 66 swb with a 4L60E it clears. i think the 4L80E is larger and will need the large hump.kenny
cru_zn_29 is offline   Reply With Quote
Old 05-29-2012, 11:29 PM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
Here are a couple of pictures of a removable low hump. No idea what year truck it came from:
Old 05-30-2012, 01:03 AM   #17
Trap62
Trap62's Avatar
Mine looks like that. 1962 SWB BBW side step built in the Los Angeles plant.
Trap62 is offline   Reply With Quote
Old 05-30-2012, 05:06 AM   #18
sigshooter
sigshooter's Avatar
That is it.... They may have come on several or every year, I don't know. I have been messing with these trucks for 25 years and have personally only seen a handful and all have been on the 1963 models. I have never personally seen one on a 456 model.
Anyone else have more info on the bolt in low hump?
1966 Short stepside
1964 long bed
Old 05-30-2012, 12:04 PM   #19
rideblue00
rideblue00's Avatar
Wow, thats cool! Never seen that before. Any reason they might do that in the early trucks and not 456 years?
Old 05-31-2012, 01:51 AM   #20
Heater63
Heater63's Avatar
Mine has the picture sigshooter posted. It is '63 Short Step built in St Louis with a 230/3 on the tree.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 05-31-2012, 02:21 AM   #21
Dino Driver
Dino Driver's Avatar
I'm putting a 4L80 in my 1960. The 60 cab I have has the removable high hump but I have a weld in low hump that I'm going to try really hard to use. It will be a while until I get there, I hope you have good results!
Dino Driver is offline   Reply With Quote
Old 05-31-2012, 03:27 AM   #22
Trap62
Trap62's Avatar
These shots are of my 1962 removable small hump.
Old 05-31-2012, 08:42 AM   #23
Heater63
Heater63's Avatar
Wow Trap, nice low rust original floor/cab! No patch panels, even the rockers are original?! Rarely see that anymore!
292 + TKO500
Old 05-31-2012, 02:09 PM   #24
Rusty one
Rusty one's Avatar
Dam,that floor is clean & rust free!!!
Rusty one is offline   Reply With Quote
