Old 05-27-2012, 09:42 PM   #1
jocko
jocko's Avatar
big block vs tunnel hump...
Are all big block trucks big hump?
Are all 4x4s big hump?
Are all 2WD non-big block small hump?
Thanks!
Old 05-27-2012, 09:46 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: big block vs tunnel hump...
Two wheel drives with either the SM-420 or SM-465 4 speed transmission have the high humps.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-27-2012, 10:05 PM   #3
71swb4x4
71swb4x4's Avatar
And maybe 2wd with the TH400?? I am not sure on that one.
I think there have been some big blocks on here with small humps, but it is generally accepted that all were supposed to be high humps.
All 4x4's were high humps.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-27-2012, 10:55 PM   #4
Beat68CST
Beat68CST's Avatar
My 327 Turbo 400 truck has a small hump.
You can fit a 400 with a BBC under a small too.
Beat68CST is offline   Reply With Quote
Old 05-27-2012, 11:32 PM   #5
jocko
jocko's Avatar
71swb4x4 -i had the same wonder - i.e. if the hump was for the TH400 of for the BB itself. Apparently it's for the engine, but not sure why - since it will fit the bb/th400 combo under a small hump apparently. Interesting. I'll "bet" it was because of the th400, even though it fits. Can't imagine what the engine would have to do with the hump unless it somehow dragged the trans a little higher with it.
Old 05-28-2012, 12:55 AM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
I had a big block cheyenne 3 on the tree with a low hump...
And all 4x4 should be high hump.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-28-2012, 09:04 AM   #7
I've had small block/TH400 trucks with small hump. I've had big block/3spd trucks and don't recall how they were,but I believe they were small hump. I think it was about extra cooling/air space for the big block/TH400 more than fit.
Old 05-28-2012, 12:38 PM   #8
jocko
jocko's Avatar
very interesting. lookin at a truck with 402/th400 and didn't notice - but when checked the catalog for carpets later, noticed that all bb trucks would get a high hump carpet if order per the catalog (which of course doesn't mean they know what they're talking about). Bottom line, get the truck, see the hump, then order... Thanks gents, very helpful!
Old 05-28-2012, 12:42 PM   #9
manimal
manimal's Avatar
I had a 1972 C20 with a big block/Th400 and small hump.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-28-2012, 01:07 PM   #10
too much stuff
Roadtrip!
Every 71-72 with a big block/400 combo i have seen was high hump. Was the truck original?
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 05-28-2012, 01:24 PM   #11
manimal
manimal's Avatar
The spid said it came with a 402(400) and the TH400. and the vins matched.
-Lance
Old 05-28-2012, 02:12 PM   #12
71 super
71 super's Avatar
I had a 69 that was a factory bb and th400 c20 that was a small hump, my 68 1/2 ton is th400 with low tunnel,my 1/2 ton 70 and 71 bb trucks are th400 and high humps.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-28-2012, 04:18 PM   #13
ole dollor
ole dollor's Avatar
i believe that the big hump was for the old four speed trans only, the shorter hump was for everything else...
ole dollor is offline   Reply With Quote
Old 05-28-2012, 04:53 PM   #14
jocko
jocko's Avatar
I would have assumed the same - but for SOME reason - LMC lists their carpets for all 4x4s and big blocks as high hump. This has turned into a very interesting thread - plenty of proof out there from y'all that proves it really could come either way with a big block and/or a TH400. The 4-speed theory makes sense, but is also disproven by all the folks out there with original big blocks and th400s that have a big hump. Apparently, there's no rhyme or reason! Thanks for posting guys.
Old 05-28-2012, 05:12 PM   #15
LMC is not a good reference. They should simply list the carpet for high hump or low hump like everyone else does.One more thing to prove they are not GM Truck guys. Through the years engines,transmissions,and cabs have been swapped. C-series bodies have been put on 4wd frames,too. Just go by what you have NOW.
Old 05-29-2012, 06:42 PM   #16
Fitz
x2!
Fitz is offline   Reply With Quote
Old 05-29-2012, 06:52 PM   #17
hugger6933
My 68 GMC came with the high hump it has and alawys had a t400. I also belive it to be a big block truck but for now it is a small block. The owner before me had it since the late 69's and traded the 396 for a 350 to some kids that offered to do all the work in the late 80's and said he diid'nt need all that power
hugger6933 is offline   Reply With Quote
Old 05-29-2012, 08:29 PM   #18
Originally Posted by Fitz View Post
x2!
Wrong. Anything with the 4spd did get a high hump,but not "only" 4spd trucks. 4wds with 3spd or TH350 also got the high hump. In other words,"all" 4wds got one.The reason we are having this discussion is to find the rhyme or reason to when the high hump was used with other 2wd applications such as BBC and/or TH400.
Old 05-29-2012, 09:21 PM   #19
ole dollor
ole dollor's Avatar
okadoke....sounds good to me....
Old 05-30-2012, 04:08 AM   #20
JCD
JCD's Avatar
That would mean all high humps would have a hole cut in them for the shifter..
Which is not the case..
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
