Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-28-2012, 01:22 AM   #1
chevytruck1970
chevytruck1970's Avatar
Vacuum pump???
How many of you guys are running a vacuum pump on your engines? What brand, how much vacuum, pros and cons? Any input would be appreiated.
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 05-28-2012, 12:17 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Vacuum pump???
After fighting the header evac crap I bought an Aerospace vacuum pump kit for the Nova,, Now there is one on the truck too. Work GREAT, everything nice and dry and adjustable. Only way I know exactly what vacuum it's pulling on the top end is a old gopro video happened to catch the vacuum gauge (10-12" in the traps, I should probably crank that down to about 9") . A big issue with high pan vacuums in a wet sump is collapsing the pan up against the pump pickup, especially with an aluminum pan.
There has been rumor of pin gaulling with high crankcase vacuums, but I've not seen it (yet) and maybe that is only with a dry sump system?? In comparison,, I will never go back to a header evac system.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-28-2012, 01:43 PM   #3
chevytruck1970
Re: Vacuum pump???
I've got a whole setup from gz Motorsports I got it installed yesterday it's pulling 5 at a 1200 rpm idle. It has an adjustable regulator may have to turn it down. I'm curious what it's going to do at the track I didn't have anything but a filter in the valve cover before
Justin
1.35 60ft
Old 05-28-2012, 03:06 PM   #4
Marv D
Marv D's Avatar
Re: Vacuum pump???
BTW that's making some SERIOUS steam for 10.90's @ 3750 pounds with a N/a 383. Whose heads you running?
Old 05-28-2012, 08:35 PM   #5
chevytruck1970
Re: Vacuum pump???
The heads are cast iron world products sportsman 2 they have been ported by a friend of mine in Tulsa ok. They flow real similar to afr 210cc on paper but the port is actually 227cc so there are much better heads available. I've owned these heads since 1996.
Justin
1.35 60ft
