Old 05-28-2012, 07:35 AM   #1
4DSEVEN
4DSEVEN's Avatar
What gauges are you using?
Okay I know there have been posts in the past but since there are many of us who have moved along in their projects, it would be great to see who is using what.
I am shopping for gauges now and looking for suggestions.
Please post a pic of what you are using and or recommend.
4DSEVEN is offline   Reply With Quote
Old 05-28-2012, 08:46 AM   #2
n_elsod
n_elsod's Avatar
Re: What gauges are you using?
Dakota Digital. I like Digital gauges because they are easy to read and are more accurate. Mine have the blue numbers and have an aluminum casing.
n_elsod is offline   Reply With Quote
Old 05-28-2012, 03:17 PM   #3
bwilli2
I really like the looks of the stock gauges.
That said, I'm putting a modern power-plant and transmission in, and want to stick with electronic gauges vs mechanical. (Speedo particularly.)
So, I either spend a mint getting stock gauges retrofitted with modern movements and some hidden indicators, spend $500 on an adapter/converter for the speedo and adapt the other gauges or just buy modern gauges. I've still not decided.
That said, I like the Dakota Digital VHX line.
http://www.dakotadigital.com/index.c...rod/prd723.htm
New Vintage's (http://www.newvintageusa.com/) Woodward line is also pretty good looking.
51 Chevy 3100 5 Window
Build Thread: http://www.67-72chevytrucks.com/vboa...d.php?t=516689
bwilli2 is offline   Reply With Quote
Old 05-28-2012, 04:37 PM   #4
c6_rob
c6_rob's Avatar
Whats wrong with original?
I needed a new temp because the probe broke and I wend with a repro oil pressure because its a SBC engine now. The batt and fuel got new overlays. The cases were blasted and painted. I wouldnt mind having an RPM gauge though
52 Chevy 3100
c6_rob is offline   Reply With Quote
Old 05-28-2012, 07:38 PM   #5
4DSEVEN
4DSEVEN's Avatar
Yeah I am also looking at original. The Dakota line is nice too.
Old 05-29-2012, 09:57 AM   #6
robin58
Little bit harder to find or you can I guess use the refacing kits, but I like the look of the GMC gauges:
robin58 is offline   Reply With Quote
Old 05-29-2012, 06:56 PM   #7
4DSEVEN
4DSEVEN's Avatar
Anyone using the Classic instruments line?
Old 05-30-2012, 10:33 PM   #8
FiftyTwo
FiftyTwo's Avatar
I like the look of the stock speedometer, so I made a matching tachometer.
Full story here:
http://www.jalopyjournal.com/forum/s...t=vintage+tach
FiftyTwo is offline   Reply With Quote
Old 05-31-2012, 12:02 AM   #9
c6_rob
c6_rob's Avatar
That is the awesome!! Coolest thing Ive seen in a while!
52 Chevy 3100
Old 05-31-2012, 12:03 AM   #10
bwilli2
Full story here:
That is fantastic!
