Old 05-28-2012, 10:36 AM   #1
richards72chevy
richards72chevy's Avatar
Fuel gushing out when i top off my tank.
With all the other gas cap problems going on i decieded to post my own thread so i dont hijack another one.Fuel will start gushing out from a little line in front of my engine when i top off the tank.Im not going over board when i top off my tank.I stop once that pump stops i dont even try getting to the dollar amount.The problem use to only happen when it was realy cold or hot.In recent years it seemed to happen more.I have had different gas caps and that dosnt seem to help.I do have a charcoal canister in my engine bay.Where do you guys think i should start to fix this problem?
richards72chevy is offline   Reply With Quote
Old 05-28-2012, 10:45 AM   #2
Lee H
Lee H's Avatar
Re: Fuel gushing out when i top off my tank.
I would begin by assuring all the fuel hoses and lines are routed and connected correctly. Sounds like the vent line is not connected or not connected correctly.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-28-2012, 11:14 AM   #3
cdowns
cdowns's Avatar
that hose you describe is for the charcoal cannister// that hose is supposed tto go to a high loop in the passenger rear door post b4 exiting the cab to go foward of the motor // sounds like that high loop was removed from the circuit and your gas is siphoning out due to gravity
Old 05-28-2012, 01:47 PM   #4
MVHandy
what he said
MVHandy is offline   Reply With Quote
Old 05-28-2012, 02:21 PM   #5
JDL
JDL's Avatar
do you have a pic? 72 trucks had a return line from the fuel pump
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 05-28-2012, 09:03 PM   #6
pat 70/71
pat 70/71's Avatar
Cdowns is on the money! I suffered through the same issue. Need the high loop as stated. All the best, Pat
pat 70/71 is offline   Reply With Quote
Old 05-28-2012, 11:19 PM   #7
richards72chevy
Im missing two lines coming off the canister.I do believe that high loop line is still there.My fuel pump does not have the return line.I guess i should replace that to.
