brake and turn lights
Ok so my front turn signals work, my tail lights work, but my brake lights don't work or the rear turn signals...any advise? I have a buyer coming to look at my truck and I need everything workin
On a quite night you can hear a ford rust |
Re: brake and turn lights
Maybe your trucks telling you something...."Don't sell me or you're going to regret it!" lol
When my brake lights didnt work but tail lights did, it was a brake switch issue. Don't know if that's the case with yours??? |
![]() Join Date: Mar 2012
fuses?
bulbs ok? i'd check that first |
Switched out the brake light switch and now the passanger side works, the bulbs are fine I belive ill check again
Whats the brake light switch?
I'm having the same problem |
It is a small white spark plug lookin switch that connects to ur brake peddle, easy to see and easy to replace, just unplug, spin out and replace, and yeah the truck may say no but buddy wants to trade me his 94 gmc Yukon that's already lifted on 20" rims and tuned to race,mines never seen snow and I kinda need something that i can drive and will power threw the snow
Ok so yup the switch was broken, it looked fine but was pooched, quick trip to the bone yard with deep pockets fixed my problem then just had to bump my bulbs a little bit to get a god connection and BAM turn signals and brake lights work again
How much did that part cost at your junk yard
HotRodScottsdale if you don't mind me asking Posted via Mobile Device |
Free.99 lol it's small enough to sneak out, it's about the size of a spark plug
How can you tell if the switch was broken?
No way to tell unless it's cracked or the connectors or broken,just go get one or two and unplug yours and hook a new one up before u screw it all together and see if ur lights come on
Gotta love pocket sized items at yards!
#13 |
Maybe you have the answer to my problem. Right signals work, left signals don't work and brake lights stay activated when head lights are on
Long live SLIM ------------------ At least try to buy American ![]() |
#14 |
Faulty ground wire mabey? Mine looked like they had better days so a quick regroup and some electrical tape helped me out
#15 |
Yeah. That's what everyone else is saying. I only found two grounds up front maybe I have to take it out the loom and check the entire wire. Thanks
. Posted via Mobile Device
#16 |
I had a big problem with my lights before checked every wire from my headlights to tail lights before I found my problem, found a lot of hacked in wires that went no where tucked in tight spots.sometimes its best to look at all your wires because u never know what's causeing a problem or what could cause a future one
