Old 05-28-2012, 07:56 PM   #1
Ivann G. Carbajal
Ivann G. Carbajal's Avatar
Question supercharger for 350?
anyone know where can i find a supercharger for a 1984 GMC Sierra 350
Ivann G. Carbajal is offline   Reply With Quote
Old 05-28-2012, 08:30 PM   #2
Mrknowitall
Re: supercharger for 350?
Summit makes a 350sb kit, not smog leagal in ca. Check ur local laws..
Banks makes a turbo kit. Id go that route, but again, smog is always an issue.
Mrknowitall is offline   Reply With Quote
Old 05-28-2012, 08:37 PM   #3
Ivann G. Carbajal
why would you go with the turbo is it more effective ?????
Old 05-28-2012, 08:44 PM   #4
Mrknowitall
Haha thats a subject ppl fight over all day, not one is better than another, just different. I perfer turbo due to:
No pully changes, longer life.
U can adjust boost several diff ways. Several! U can achiev cooler intake air with turbos.
However, before u even THINK of boosting antythibg, be ready to spend 10k easy. Ur motor, carb, transmission, rearend, everything needs to b changed to accept boost/hp. The turbo/supercharger/procharger alone will b 5k if ur lucky.
So ask urself, is this gonna b finished or another craigslist ad? Do u have 10k and 5 years??
Old 05-28-2012, 08:48 PM   #5
Mrknowitall
I dnt mean to discourage u, but massive changes like these cost tons of money, also remember, until u make 700+ hp these hondas will still walk all over u. Ur trucks HEAVY. Hense y most ppl blow or charge pony cars and chevells,
I suggest u save ur money. Do it all at once, if ur serious.
Old 05-28-2012, 08:54 PM   #6
Mrknowitall
I have a sbc 64corvette327 heads gear drive rv cam flamethrower ignition on relay, high resticance plugs fore. Pistons, 9:5:1 compression clevite 77"s pn stock crank all ballenced to 6k, outer cranks swapped and smoothed on 91 octane, stock carb with 5%larger jetting, mild shiftkit and 1000rpm higher stall ele fan and truck on a mild diet.
Poly bushings everywhere with brimbo brakes.
Vs
1990's acura 4cyl on 100 shot of nos,
Pulls by a bumper everytime to 115mph
I have 12k in my truck he has 4k
Hope that helps.
Old 05-28-2012, 10:40 PM   #7
Number21
Number21's Avatar
But you look cooler, sound better, and can do it while towing a boat!
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 05-28-2012, 11:15 PM   #8
andrewmp6
A blower or turbo cost money to do and with a stock small block 7 maybe 8psi is all it would run.Just remember power=money and power kills mpg too,If you want to tick him off cheaply find a mustang 2 or pinto or even a chevette throw a big block in and watch him cry lol.
andrewmp6 is offline   Reply With Quote
Old 05-29-2012, 04:43 PM   #9
Ivann G. Carbajal
well i already have a forged racing poisons bigger crack a 700 lift hydraulic roller cam 150 cc heads 700r4stage3 shift kit with 4:10 gears possy traction ....and more ....do y'all really think I'll need to build any more to add any power adder like blower or turbo
Old 05-29-2012, 05:18 PM   #10
Pop's C-10
Pop's C-10's Avatar
700 lift cam & 150 cc heads...to much cam...way not enuff head
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 05-29-2012, 05:29 PM   #11
Mrknowitall
Cams pretty wicked, whats ur bottom end like? Id go skat crand arp bolts 4bolt main, some strong h beam rods.
Top end ull need some valve springs to match boost. Arp head bolts with boost approved gaskets.
Whats ur compression with those pistons? U need to b at 7:5;1 i believe?? Idk on that one..
Sounds like that motor would b happier with nos. ?? Id ponder that route before boosting.
Old 05-29-2012, 05:32 PM   #12
thesickc10
x2 get yourself a good set of heads and it will wake that motor up.
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 05-29-2012, 05:47 PM   #13
school boy
school boy's Avatar
no offense to anyone but ive seen several guys build vortech supercharger kits with intercooler and tuned for less than 2000 dollars. granted this is on a fuel injected car and only running 8-12 lbs of boost. you can build turbo kits for around the same price, not new, not top of the line but not ebay crap turbos either. if you want big power, yea 10,000-15,000 is a reasonable starting point. but most people are going to be satisfied with 75-100 more hp. and on the street, thats reasonable. btw, i have a link to mustang site with vortech build
school boy is offline   Reply With Quote
Old 05-29-2012, 05:49 PM   #14
Mrknowitall
No offence taken! If i get facts to build a 2k 10psi build ill do it!! Whats that link!??
Old 05-29-2012, 06:18 PM   #15
school boy
school boy's Avatar
this is built with a used head unit vortech only, and all other new parts. istead of getting a discharge tube, people have been buying the cxracing universal 31x12x3 intercooler and piping for the same price. i built this exact setup intercoolered for 1200 with injectors and blow through mass air flow and i tuned it with my sniper software. took me a while to find all the parts for good prices but i wasnt in a hurry. it was a beast 2000 rpms and up and made over 400 REAR WHEEL horse power not fly wheel. the cxracing intercooler seems cheap at 200 dollars but i concidered it very good over all. it had a little more boost drop than i liked but a pulley fixed that.
hers the link
http://mustangforums.com/forum/pipes...-its-done.html
the guy did a crappy job on the intercooler install but you can get the point and idea of it
http://mustangforums.com/forum/pipes...-finished.html
heres a pic of my setup before we tore it down. btw, stock long block 4.6 sohc
Old 05-29-2012, 07:10 PM   #16
Mrknowitall
hers the link
Woah! I stand corrected! U say ls1 heads? Whats the bottom end like??
How much was the turbo? T3 garret?
Old 05-29-2012, 07:23 PM   #17
school boy
school boy's Avatar
its a v2 t trim vortech supercharger. the motor is a 01 mustang factory 4.6 (281 ci), single over head cam motor. its about 9.5:1 compression. thats edelbrock victor jr manifold with a sulivan upper and and a twin throttle body. the rods factory in these motors are good to only 400-450 rwhp. pistons same but the crank is good to around 550-600 rwhp. ford's little ol' modular 4.6's aint too bad with boost or nitrous on them!
Old 05-29-2012, 07:41 PM   #18
badpontiacs
badpontiacs's Avatar
I've build a couple of boosted cars in the past, takes alot of tuning knowlage (not Bubbas Backyard Garage lol). It has taken me about 10 years to tune with profection and to aquire equipment to do so. Just remember, 2k sounds like a hell of a deal.....do you ever see their post about their engine blowing up??? No, you really dont see that too often. I'd save and spend the money over a period of time or all at once...you will be way more pleased in the long run and the longevity of the vehicle with matched parts.
Heres a couple of my current builds..LS1 in an '04 GTO and a 502 in a '68 GTO. The '04 made 598hp at the tire on all stock bottom and heads (now has cracked piston skirt) "on a budget" build. Now im spending $ for everything new :/ The '68 made 1273hp on the dyno with out the spray (250 shot) That engine was done right, over 12k in the engine alone. I drive it on the street and not a single problem in 2 years.....except for tires lol!
So, save, research, and do it right once. If you have a shop build the engine, be there every day watching and learning. Good luck and if you have a question, PM me.
badpontiacs is offline   Reply With Quote
Old 05-29-2012, 08:12 PM   #19
bustedknuckles
bustedknuckles's Avatar
Well said badpontiacs. nice builds as well.
Research is definitely a must, but in my experience you won't completely understand it all until you do it. If it's what you want and can afford it, I say go for it.
Here's a crappy cell phone pic of my vortech setup.
84 GMCummins
91 CCSB Dually
american squarebody association
bustedknuckles is offline   Reply With Quote
Old 05-29-2012, 08:41 PM   #20
school boy
school boy's Avatar
ive yet to see a lot of those car blow from that build. most of the ones that did were pushing the limits of the engine and knew they were on borrowed time. a great tune is the key to keep the engine alive and healthy but with any upgrade to a stock engine, you are cutting its life shorter.
Old 05-29-2012, 09:05 PM   #21
Ivann G. Carbajal
i just had my bottom end built completely built up to take a big beating i went all out as for the heads what would yall recommend also for a intake what2? i have a dual plane intake .....abs i thought off nos but will the power addition of noss would it be full time? ??!!!
Old 05-29-2012, 09:08 PM   #22
3r!c84
Badass
3r!c84's Avatar
from what you said with a 700 lift cam and little 150 cc heads you need to re-think your whole idea of building this motor. not to be rude just saving you alot of time and money for nothing that works together at the end result
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-29-2012, 09:08 PM   #23
Ivann G. Carbajal
I've also considered putting a LS engine don't know which one would yall recommend it our would it be too much of a hassel in adjusting
Old 05-29-2012, 09:10 PM   #24
Ivann G. Carbajal
my heads been ported
Old 05-29-2012, 09:17 PM   #25
badpontiacs
An LS is an excellent platform. I'd do an LQ9 iron block from trucks and vans usually 6.0L.
