Bad rear diff leak
Well I have been noticing lately a noise coming from my rearend so today I pulled the fill plug and could not fill any fluid so I topped it off with gear oil and off I went well I get home and parked it later I look outside and see all of my gear oil is on the ground I am assuming the pinion seal thats where it looks like it has been leaking so tommorow I'm going to pull the cover check everything out and put a new pinion seal in it.
Just curious can anyone tell me what size socket I need to remove the pinion bolt on an 86 k10 10bolt rearend Posted via Mobile Device
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
18 Till I Die
Re: Bad rear diff leak
Not off hand, but make sure you mark the nut/pinion/yolk before you take the nut off.(center punch) Then when it goes back together just go past your mark by a bit to get some crush again on the sleeve.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
