05-13-2003, 10:39 PM | #1 |
One of my kids. Cute eh?
axle swap on a 70
Hey,
Two questions: 1. I'm junking out an 85 Suburban. I am taking the whole engine cradle and disk brake assembly out and installing it into the 70 Chev pickup. I know that will work. But I also want to install the rear axle into the 70 (the one from the 85). I'm pretty sure the axle is about a 1/2" - 3/4" wider which shouldn't matter. Or will it? 2. I had found a supplier on the internet that sold all the brackets to mount a leaf type axle into the trailing arm setup on the 70s. Does anyone know what company had this? I think it was around $160 for the brackets. You just cut off the old leaf spring brackets and welded the new ones on. Saved the hassle of trying to cut the old ones off the trailing arm axle neatly. The good news is I decided to install the 454 and 400 turbo trans into the 70. I asked for a vote a couple of weeks ago and it was 100% for the 454. Which is what I was leaning towards anyway. This ought to be interesting. Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did. John 3:16 2006 Chevy HHR 2000 Dodge Durango 1985 Jeep CJ-7 1970 Chevy Pickup |
05-14-2003, 12:47 AM | #2 |
if the 85 has 12 bolt just change out the axles, if not ECE http://www.earlyclassic.com/ has the sadles for that conversion for i believe 49.95
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
05-14-2003, 08:45 AM | #3 |
Would this swap work on the late 70 models as well?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
05-14-2003, 09:28 AM | #4 |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
