Old 05-28-2012, 11:25 PM   #1
x1buellist
x1buellist's Avatar
stepside Rear cross sill
I am restoring the bed on my 66 short stepside. I have taken most of it apart. I wanted to remove the rear cross sill and I have unbolted it. It wouldn't budge and than I realized the rear cross sill is welded to the stake pocket. I could easily cut the weld and since there are 4 bolts very near the weld holding it to the stake pocket. I am thinking it doesnt need to be welded there and I can just bolt it back on after I recondition it. Any thoughts on this?
Here's a pic with the weld circled. The bed is upside down and mostly disassembled in the picture.
x1buellist is offline   Reply With Quote
Old 05-29-2012, 01:28 AM   #2
chopper john
chopper john's Avatar
Re: stepside Rear cross sill
i had the same issue on my 60 . i cut it out . when i put it back on i just bolted it back
chopper john is offline   Reply With Quote
Old 05-29-2012, 10:53 AM   #3
oldsnakebite
oldsnakebite's Avatar
I did the same on my 64, used a cut off blade on my dremel tool, replaced the rear sill and just cleaned up the weld and then just bolted in back without welding.
I have not failed. I’ve just found 10,000 ways that won’t work.
oldsnakebite is offline   Reply With Quote
Old 05-29-2012, 11:17 AM   #4
x1buellist
x1buellist's Avatar
OK great, I will just bolt mine back together also. Thanks.
