Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 05-28-2012, 11:44 PM   #1
richards72chevy
richards72chevy's Avatar
How are you guys keeping engines off the floor?
Im going to be swapping the engine and suspension on my 66.I plan on renting a engine lift.So i will need to keep my 305 v8 and trans stored on the ground for a few days or weeks while im doing the crossmember swap.I have seen people put them on old tires and even wood pallets.I can get some pallets for free at my job.What do you guys recomend?
richards72chevy is offline   Reply With Quote
Old 05-29-2012, 11:21 AM   #2
Lee H
Lee H's Avatar
Re: How are you guys keeping engines off the floor?
I use a cradle I got from HF. I slightly modified the rear attachment points so I could leave the trans attached.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-29-2012, 03:37 PM   #3
NONHOG
NONHOG's Avatar
2x4's, 4x4's, plywood stacked and cut out to fit tight to the oil pan.
I usually have so much stuff around, I just find what fits.
A spade bit can recess a 5/8 piece of plywood if your drain plug makes it tippy.
Or a chunk of foam board insulation in with the above ideas will keep it dent free.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 05-29-2012, 03:41 PM   #4
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I have two engines sitting in my shop on some $10 harbor freight 1000lb furniture dollies. Cut some 2x4s to stabilize them on the dollies and they are easy to roll around the shop. I have a engine stand too, but I save that for something I'm actually working on at the time.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 05-29-2012, 10:34 PM   #5
jkrenzel
jkrenzel's Avatar
built furniture dollies out of scrap, and wood pallets which are free and easy to find
jkrenzel is offline   Reply With Quote
Old 05-30-2012, 01:28 AM   #6
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I use old tires. Works great and it's free.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-31-2012, 11:36 PM   #7
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Could you put it in the bed of the truck?
Personally, I'd separate the two, cradle the engine
in a tire and put the trany in a leak-proof pan.
(Many lumber yards carry the big, heavy duty pans
for mixing grout).
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 06-01-2012, 07:04 AM   #8
richards72chevy
Thanks for all the info.I could put it in the bed but im doing this in a little two car garage with half of it being the laundry room.My main concern was damaging the oil or trans pan.How many tires would you guys use to keep the engine and trans off the floor?
Old 06-05-2012, 06:51 PM   #9
thesickc10
i use two truck tires and for the trans i put them right on the floor they usually have pretty strong pans.
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 06-05-2012, 08:10 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have an engine stand, if the engine is by itself. If I have it as an accessories-on longblock or an engine trans combo, I use a 1200lb furniture dolly. They hold the engine trans combos great, while not putting weight on the oil or tranny pans themselves. Plus they move and are low pro if you need to slide something under a car on stands. Pretty good use of $40
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-06-2012, 12:47 AM   #11
CG
BlahBlahBlah
I have a couple sitting on tires and I have a Caddy 500 on an inexpensive (but the heavier duty one) engine stand from HF. Its been on there for a few years and shows no sign of hitting the ground lol.
Old 06-06-2012, 02:25 PM   #12
Warrens69GMC
Warrens69GMC's Avatar
Pallets that people throw away.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-18-2012, 01:18 AM   #13
sleepertruck72
sleepertruck72's Avatar
Just let it hang on the cherry picker. It may even rest on the legs of the cherry picker with the tranny attached. I have one you can borrow if you need one.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 06-28-2012, 12:53 PM   #14
Billett
Billett's Avatar
I've got two on tires, ones been there for almost a year and nothing has happened to it. We did have them on pallets at one point and they were fine there too
Billett is offline   Reply With Quote
