Old 05-29-2012, 03:02 AM   #1
BenE
Whats breaking my rad support?
I have a 71 C-30 that the rad support keeps breaking on. It breaks on all 4 corners of the opening for the radiator. Its not been in any major wrecks that I know of( not in the last 22 yrs at least),no noticable vibrations, rides and drives great. Has anyone seen or heard of a truck doing this? This will be the third rad support for this truck plus several weld jobs. Any ideas or suggestions will be appreciated.
BenE is offline   Reply With Quote
Old 05-29-2012, 06:57 AM   #2
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Whats breaking my rad support?
What condition are the body (and radiator support) mounts in? Also, are you sure you have the correct ones? The C30 uses different mounts then the C10 and C20.
You can try jacking up one corner of the frame and see what and where it flexes....
Rich
1972 K5 Blazer CST Click HERE
Old 06-01-2012, 09:34 AM   #3
BenE
rad support mounts were in good shape, cab mounts not as good. Got new ones ordered for both.
Old 06-01-2012, 09:53 AM   #4
farmall
farmall's Avatar
My 71 C30 has the same symptoms.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 06-01-2012, 02:23 PM   #5
YBNORML
YBNORML's Avatar
I pulled my rad saddle out of a 68' c30 and it is also cracked in the corners of the rad opening.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
