Old 05-29-2012, 10:17 AM   #1
blazer2007
tight caliper ?
took my truck out yesterday [1980 chev 2 wheel dr.] and went for a short ride and could smell a cross between rubber and burnt wire when I got home and noticed the dr. rim was a lot hotter than the pass. side.Jacked the truck up and dr. side was hard to turn so took tire off and loosened the bearing nut but that wasn,t it,so I let a little brake fluid out and helped a little.Do these type of calipers have a problem when sitting too long,has been sitting outside since Oct.Is there something I can do.Also is there a better caliper upgrade with little or no modification for these trucks
blazer2007 is offline   Reply With Quote
Old 05-30-2012, 09:16 PM   #2
Chevydude56
Chevydude56's Avatar
Re: tight caliper ?
If you let brake fluid out of the bleeder brake released , it could be that you have a restricted brake hose at that wheel . I would check that first.
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 06-07-2012, 07:39 PM   #3
starvinartis
Re: tight caliper ?
Agree with Chevydude, but if it needs calipers, around here rebuilds are like $15 ea or less
starvinartis is offline   Reply With Quote
