Old 05-29-2012, 04:53 PM   #1
zippeay
zippeay's Avatar
Trans crossmember help
Ok, I've been looking around for a few hours and I think I'm just looking in the wrong places. Basically I'm trying to make my 64 lay frame, I've done the rear notch, put a 76 front crossmember in and I'm about to Z the front but.... the trans crossmember is already hitting the ground. Obviously I need to either take it out or move it up "I'm assuming I have to have it if I'm putting the 350 w/turbo 350 back in correct"? Does anyone have pictures of one that is modified for this situation? I can't seem to find any pictures but I'm sure I need to move it up at least a 2 probably more like 3 inches? Also once I do that will the big trans hump solve the problem of the trans hitting the floor? I found a big trans hump from a 4x4 but I'm not sure even that will be big enough for this. Any help would be highly appreciated. Thanks!
zippeay is offline   Reply With Quote
Old 05-29-2012, 05:19 PM   #2
Raked 64
Raked 64's Avatar
Re: Trans crossmember help
Scroll down to the suspension section of the forum. That seems to be the place for bagged knowledge.
Raked 64 is offline   Reply With Quote
Old 05-29-2012, 06:19 PM   #3
padresag
if you raise the back of the trans then one should raise the motor an equivalent amount
ron
padresag is offline   Reply With Quote
