dropping my truck
I have an 85 swb Chev. i am looking at a 5/7 drop. my truck has 275/60/15 tires all around. i want to keep the 15" rallies. i assume these tires are to big for the front end. what size tire is recommended? i have heard you have to trim the lca to keep the 15' rim, this is fine. does anyone have a pic of how much has to be trimmed? which brand kit is preferred? is a 2.5 spindle 2.5 shock a better set up than a 3 in spindle 2" spring? i have read that 3" springs are not recommended due to ride, so i will stay away from those. any more info or opinions from people who have 5/7 drops is appreciated. if there is any other major complications with this setup? this truck is a weekend cruiser.
Re: dropping my truck
look here my friend:
http://67-72chevytrucks.com/vboard/s...d.php?t=526895 |
truck looks wicked! what kit did you use? you have 235 70 all around? did you have to trim the lca?
2.5 spindles no, mcgaughys all the way around. the springs i dont know though. and yes, all tires are 235/70/15 with no trimming required
Looks like a clean truck, and would look sweet lowered! Let us know if we can help you out with the components. We carry McGaughys.
A 2.5" spindle, 2" spring up front, with a flip kit would give you a nice stance. |
I have 2.5" spindles with 2" springs up front, and a flip kit in the back.
If I did it again, i would only use 1" springs up front to eliminate the rake, and give my big balloon tires more clearance to the inner fenders. |
Here u go, answers all ur questions
http://67-72chevytrucks.com/vboard/s...d.php?t=525669 Posted via Mobile Device |
Diggin The SquareLife
u will need to run a 255/60/15 in front...check out my thread to see pics
