Old 05-29-2012, 07:24 PM   #1
handyhands
S10 mock up
O.K. s10 guys, I am starting to line up cab and fenders. I have read to start with 4x4 blocks. If I use the s10 bushings on the body mounts how would I adjust for the height? Has everyone used some kind of bushing? Any pictures would be great. 53 3100/s10
handyhands is offline   Reply With Quote
Old 05-29-2012, 08:12 PM   #2
swizzlestick
Re: S10 mock up
i believe the stock s10 bushing and pad adds 1.5inches to the height. so you can mount higher with 4x4 plus bushings or subtract 1.5 inches to get your final mount height to go lower. I'm still in mock up stage myself so someone that has it done may tell you differently. so far im going with 3inches total off frame which puts me just above stock s10 gas tank.
swizzlestick is offline   Reply With Quote
Old 05-29-2012, 08:48 PM   #3
ozzie50
Re: S10 mock up
I used energy suspension universal bushings not to thick like the s-10's and a lot cheaper for a new set and not a big cup like the s10's. I won't know till I get it one the road if I made the right choice or not.
ozzie50 is offline   Reply With Quote
Old 05-29-2012, 09:46 PM   #4
dubds10
Stalker Nate
Re: S10 mock up
For S10 bushings, I usually see 3" mounts used since the bushings are 1.5-2" tall so a total height of 5" which is required. Will be doing one that way fairly soon, when it gets into the shop. Get some 4x4s and use them under the cab..they should be pretty close to the height you need, so you just align everything from there then put the mounts on.
Nate
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 05-30-2012, 01:41 PM   #5
62ChevyII
Re: S10 mock up
Mock up the cab and body where you want it then build the mounts to it. You can fine tune it a little with big washers or something like that later if need be.
My S-10 swap thread: http://www.killbillet.com/showthread.php?t=16296
62ChevyII is offline   Reply With Quote
Old 06-06-2012, 09:34 AM   #6
1952ssr
1952ssr's Avatar
Re: S10 mock up
I used them on the rear for mine.
1952ssr is offline   Reply With Quote
