Starting issues after reaching operating temperature
I have a 68 c10 with a 400 sbc. It's runs 11:1 compression with Keith black pistons. It has a edelbrock performer rpm top end. 850 speed demon carb and a complete MSD 6AL ignition. I run a electric water pump and fan and just recently had a 18 circuit wiring harness installed. As well as a new hi torque mini starter. My issue is after I start my pickup and it get to operating teperature and turn it off it won't start untill it cools. It does this untill my battery drains. I just had my alternator checked and it passed. I was told not to ground my battery to my aluminum heads so I moved the ground to the frame and i still have the same issue? Thx for any advice anyone can give.
Posted via Mobile Device |
Active Member
![]() Join Date: Jul 2007
Re: Starting issues after reaching operating temperature
First, welcome to the site...
I'm assuming here that when it does run you have no issues with it until it gets up to operating temp. Since I'm not familiar with any carb but quadrajets the first thing to check is the choke, if you have one, to make sure it opens up completely when warmed up. Next is to check inside the carb throat to see if it is flooding. Check with a flashlight and see if you can detect any dripping or a strong gas smell. You should notice black to dark gray smoke on startup out the tailpipe. Check the battery cables at the end connections to make sure they're clean and if they're old, replace them. They corrode internally at the connection and it's not visible because of the insulation. Check the battery posts with a vdc meter for 13.5 to 14.5 volts give or take. Mine checks out at about 13.8 volts when idling. The only other thing that's a possibility is if the piston rings were not gapped correctly and expanding when engine is warm seizing the engine until it cools and they contract again. I've seen this only once but it can happen. |
![]() Join Date: Apr 2003
check your timing too
The piston ring issue sounds like a possibility. Because shortly after getting my engine built I was getting oil spitting out my dip stick. So when I took it to a mechanic other than the one who put the engine together to do a compression test I was loseing compression anywhere from ten to twenty five percent compression per cylinder. So when I took it back to the mechanic who built it he reved the engine and poured automatic transmission fluid into The carb while reving it. After doing so the blow by stopped and oil stopped coming out the oil dipstick. could this hAve caused the ring gap to expand? Also the timing is at 14 degrees advanced if I remember correctly.
#5 | |
Active Member
Play with the timing some. Maybe move it to 8 or 10 degrees btdc. Also check the vacuum advance to make sure it's working (you can use mouth suction) then hook it up to manifold vacuum if it's on ported vacuum. Last edited by 68gmsee; 05-30-2012 at 09:35 AM. |
It doesn't die on me. But when I shut it off there is no squeak but it does stay on for a second or two when the ignition is off an it sounds like pressure being released.
I had a similar issue with mine several months back and it turns out it was a hot start problem. The heat from the motor/intake was boiling the gas in the carb. I had to wait several minutes until it cooled down before it would start. I put a carb spacer on and it fixed the problem.
1963 Chevrolet C10 Short Step 1968 Chevrolet C10 Short Step |
I dare say it is heat soak after you shut it off. try a 160* T-stat if you do not have one in already. 14* to 16* initail is normal for spicy motor what is the LSA and duration for the cam Maybe you can back it off tad. I myself never worry about initail I check for total advance 36*@ 3000 rpm. Does it crank over or does it ring the flywheel and not rollover when at this heat soak period. my LT1 motor is 11-1/2 with pop up pistons. when it hits the
90* mark its gets cranky (LOL) I know to let it set for an hour before restarting. At the racetrack I use fans to cool the engine bay between runs. Hope this helps. |
![]() ![]() Join Date: Jan 2011
Assuming it has headers on it? Do you have a heat shield on your starter .. or is the header pipe really close to the starter solenoid? Sounds like heat soak to me. (starter problems)
I usually run a big block high tourqe starter on high compression motors. So when you turn the key it doesn't even grunt like it's trying to turn over it sounds like ?? .. if it tried to start up like it wasn't getting any fire then I would think carb or vapor lock / boiling in the bowls.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
So if it is heat soak on the starter won't a 160* therm help with that
I wouldnt think so. If the header is close to the solenoid that tube can reach 1000 degrees or more. Ots essentially cooking the solenoid. As it cools it fires off again.
You could also try to fab up an aluminum heat shield for it, just something to keep that crazy hot header tube off or at least away from the starter. I had a 69 camaro with this very same problem and the heat shield took care of it. Posted via Mobile Device
Would a header and exhaust wrap work?
#13 |
![]() Join Date: Mar 2003
Put the ground cable back on the engine. Get a 2 ga. cable and put it as close to the starter as you can. Also put a 2 ga. pos cable on the starter lug. Another possibility is the purple wire for the cranking, the eyelet over time has a tendency to attract oil from leaking valve covers and such. Another thing is the quality of the battery and the CCAs
#14 | |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#15 |
Post up a picture of the exhaust tubes as the run down by the starter. Pass side of course.. just to see how close it is..
Yes header wrap might help too.. Not saying this is the problem but definitely a possibility. Speaking from experience ![]() Posted via Mobile Device
#16 |
Starter like above or I'd check the timing.
#17 |
Does it have an HEI in it? maybe that resister wire?
#18 |
Correct 68 gmsee. Like the starter ales a half turn n that's it then just clicks after that
#19 |
Turns not ales sorry
#20 | |
Active Member
Couple more questions. When it cools off and you try to restart does it crank over normally or very slowly like it's struggling? Did you check the voltage between neg and pos at the battery while it's running for the 13.5 to 14.5 +/- vdc? |
#21 |
Yes the starter makes a sound and turns like a half a turn then stops then just clicks after that. but doesn't turn over. And yes it's stays running on its own. And yes when it cools it starts normaly it doesn't struggle. And no I haven't checked the Voltage between the neg and positive on the battery.
#22 |
@ cc69rat is has msd pro billet distributer with a 6al ignition box n msd coil
#23 | |
Active Member
I would start by rigging up some way to keep heat off the starter first. Maybe a piece of sheet metal. Then maybe use some compressed air (can) to cool the starter after the truck gets warmed up to operating temp. to see if it starts quicker. Next, for funnsies, I would: 1. have the battery load tested. 2. Replace the battery cables if they're old and ensure the ground cable to the block has good metal to metal contact. 3. Maybe try a different starter. There's a lot of vehicles running with headers and don't have any problems so it may be worth a try. |
#24 |
BA - check out this post when you have time.
NoNeck is my dad. My GMC had a similar issue going on. He found the problem to be a resistor wire still left in the wiring harness. Has your truck been converted to HEI? Maybe your resister is the problem like mine? PM dad if you want. He figured mine out and still has the pictures / parts he removed. It was pretty crazy. http://67-72chevytrucks.com/vboard/s...d.php?t=524926
#25 |
