Old 05-29-2012, 08:32 PM   #1
86 C10 LT1
lt1 swap fuel problem????
I have an 86 c10 I just put in an lt1 and wired it had the pcm to remove vats and emissions starts up and dies I check fuel pressure and it was very low its supposed to be at least 40 ps1 mines at about 15 psi was wondering if my fuel tank is the problem I bought a external fuel injection pump that produces up to 50 psi it was recommended from lt1swap.com so not sure what to do?
86 C10 LT1 is offline   Reply With Quote
Old 05-29-2012, 08:43 PM   #2
fxdxharley
Just a nother gear head
fxdxharley's Avatar
Re: lt1 swap fuel problem????
you should post this in the engine faq section.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 05-30-2012, 12:41 PM   #3
youngrodder
youngrodder's Avatar
Are you running any type of fuel filter? It might be plugged. My LT1 that sat for many years before I fired it. I had to tap on the injectors to free them up to get the idle to smooth out by my fuel pressure was always where it was suppose to be. I'm using a fuel pump in the tank.
Did you run it by people on LT1swap?
Good luck
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-05-2012, 09:09 PM   #4
86 C10 LT1
figured it out my truck came with the dual tank setup so i removed the one tank on the passenger and the electronic valve and made new lines going directly to the drivers side tank and my psi jumped straight up to 40 psi and truck fired up in an instant! thanks guys for help
