05-29-2012, 10:58 PM | #1 |
Door handle buttons
Why are the outside door handle buttons pushed in on some trucks. How do you fix it?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
05-29-2012, 11:06 PM | #2 |
Re: Door handle buttons
Pushed as in stuck? I'd love to know too? Mine will stick from time to time, usually a good smack will pop them back out though.
05-30-2012, 12:23 AM | #3 |
yes, stuck in an inch or so
05-30-2012, 12:36 AM | #4 |
If there sticking I would try lubricating the channel on the inside, this requires taking off door panel the spray inside handle button.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
02-05-2015, 05:33 PM | #5 |
Mind if I bump this?
My handles are doing the same thing from time to time. Press the button and it won't pop back out. (Mine is an 81) |
02-05-2015, 06:24 PM | #6 |
You will need to replace the handles. If you remove the handle, you will see the plate on the back side that aligns the button is falling apart from corrosion.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
02-05-2015, 08:28 PM | #7 | |
As an alternative to replacing the handles, I have had good luck fixing this type of problem by riveting in a small section of angle iron. One leg of the angle is drilled for the pushrod to pass through and oriented so it replaces the original plate. The other leg of the angle is oriented so it can be riveted to the inner part of the handle. Use rivets with countersunk heads so they don't interfere with fitting the handle back into the door opening. |
02-05-2015, 08:36 PM | #8 |
Sorry,
It will pop back out nice and strong. It's just getting stuck in if pressed back fully sometimes. |
02-05-2015, 09:07 PM | #9 |
Okay, in that case it's probably just a lack of lubrication. Like chevy88 posted earlier, you can remove the interior door panel and spray the back/inside of the handle.
