WTB 8 inches of 2" rubber fuel neck
I refuse to fund the local u pull yards as they mostly have been bought up by a steel scrapper corporation (prices nearly doubled). I need 8" to a foot of rubber fuel filler neck/hose to complete my fuel tank conversion. Anybody have a scrap left over they want to sell?
Moderator
![]() Join Date: May 2007
Re: WTB 8 inches of 2" rubber fuel neck
a marine shop will have what you need if you have no luck here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Never thought of that! The local parts stores only sell it in 3' minimum lengths. Thanks for the tip!
What?
Check around your area for an industrial hose supply house.
I buy mine from a local shop that caters to forklifts and big rigs, and they have a huge supply of all grades of hose. In case you can't find anything in your area, perhaps you can mail order what you need from the place I go to. www.hose-man.com I will look around for the exact ID size for you, I have a picture of the hose I use around here someplace.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
![]() Join Date: Feb 2008
I went to NAPA (the real parts store) and i got the exact same 2" hose that was on my Suburban. It happened to be a coolant hose according to the description. It was used as the fuel hose because it doesn't have a constant presence of fuel running thru it. When i spoke to the original owner of the suburban i bought, he told me that hose had been in place for about 12 years. The only reason i took it off was to swap bodies and the hose wouldn't come off. It was still very pliable and no cracks or anything wrong with it.
I tried the other parts stores, and they either didn't have the exact same size hose. And the closest size they had would only sell it in 3' lenghts. Try NAPA! |
