Old 05-30-2012, 11:00 AM   #1
cfan10
cfan10's Avatar
Cool Please, help window/alarm woes...
Ok, truck won't start but I'm in the process of replacing fuel pump, and finding a fuel line that goes from the fuel pump to the filter hose for less than $60.
I have a new battery installed, and my pwr locks work fine but the windows will not even try to go down. What could be the cause of this, because the motors/switches are fairly new and the switches are secure to the wires.
Also, my viper alarm is not working properly the blue light does not blink (damn best buy) I disconnected the headlight switch on the dash, could this be the culprit? I need my windows to work since I've disconnected the ac.
Any advice with these issues will be greatly and sincerely appreciated. Thanks.
84 swb 305
Viper hv350
cfan10 is offline   Reply With Quote
Old 05-31-2012, 11:46 AM   #2
cfan10
cfan10's Avatar
Cool Re: Please, help window/alarm woes...
C'mon, guys let's put our thinking caps on, lol and figure this out. With all the 10's on this site I'm sure someone else has faced this problem.
I going to check all the fuses in a bit, but if that's ok wondering where I go from there. Thanks.
Old 05-31-2012, 11:57 AM   #3
cfan10
cfan10's Avatar
Not the fuses, any ideas?
Old 05-31-2012, 12:01 PM   #4
84_chevy
I'd don't know anything about the power windows on these trucks, I couldn't afford that option so I only have a plain Jane with roll down windows
If both window wont work I'd say your problem is somewhere within the circuitry, its highly unlikely you blew both motors at the same time.
84_chevy is offline   Reply With Quote
Old 05-31-2012, 01:51 PM   #5
Square_78
Square_78's Avatar
voltage regulator?
Are the power windows and locks connected to the viper alarm?
Square_78 is offline   Reply With Quote
Old 05-31-2012, 04:30 PM   #6
v30crewcab
v30crewcab's Avatar
is the relay good? no ideas, mine has manual, kinda like it that way.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 06-01-2012, 03:51 AM   #7
Square_78
Square_78's Avatar
Pretty hard to troubleshoot an electrical problem with little or no info. Get out the multi-meter and check the voltage at the power window fuse, switch and relays and make sure everything has power. If everything has power then it might be the motors. You just need to get in there and start testing. It could be one of many different things.
