How Do You Remove the Knobs from Heater Panel?
I am replacing a missing lower heat control arm on a '70 GMC. I have a replacement arm with the little chrome knob, but can't figure out how the knob comes off the arm. Does it just pull off? I don't want to break my replacement arm if I am missing something.
I can't remove the replacement arm from the old panel with the knob on. Thanks, NoNeck
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
The Older Generation
Re: How Do You Remove the Knobs from Heater Panel?
Yes, they just pull off. They can be tough to get off. I don't have any secret chants or VooDoo spells to make it easy, but if you can get something behind them and pry a little bit they should come off. Just move the lever to the off position and put some kind of padding on the face of the panel to protect it. LockDoc
I use a pair of needle nose pliers and close the jaws gently up to the lever so that the knob is touching the needle nose. Once the pliers are in place I use a small hammer against the needle nose pliers to drive the knob off.
It works well and the knob is not damaged. A small thin open end wrench would probably work also. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
