Old 05-30-2012, 03:37 PM   #1
glljr
Pulley's
So I put my motor in this weekend and because of the heads not having the acc holes I moved the alternator to the passenger side and also have the long water pump. My problem now is that all my pulley's line up to use just one long belt is this ok to do?
glljr is offline   Reply With Quote
Old 05-30-2012, 03:55 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Pulley's
With the alt, water pump, and crank... yes.
If you got P/S... that should have it's own belt.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-30-2012, 05:44 PM   #3
glljr
Re: Pulley's
I do have p/s but its lining up with the rest of the pulley's with the same belt instead of being on its own
Old 05-30-2012, 08:42 PM   #4
GASoline71
GASoline71's Avatar
Re: Pulley's
I would run P/S on its own if you're runnin' a V-belt.
Gary
