Need helpf with Single wall side glass.
Just picked up a nice single wall hard top, with roof rack. However, it doesn't have any glass in the side window. I have a double wall top, is the glass the same in double and single? Also, it has one low spot in the roof, unlike my double that has four.....How do you fix the low spot? Does anyone reproduce these? thanks everyone for the input!
![]() Join Date: Sep 2010
Re: Need helpf with Single wall side glass.
I can only answer the side glass portion at this time, no they are not the same. Dbl wall top has thicker side glass. Have not figured out repairing roof sage yet, way down the road in my build. Tops are not reproduced, the hatch is but I hear it sucks.
don't know how much sag you're talking about on your double wall. but they all puddled from day one. never seemed to hurt anything though.
I changed out my dbl wall to a single wall on my 71, holes in bed rail did not match some say they do. Also broke the glass out of one side of my single wall and replaced it with one out of my double wall, seal and glass fit nice. The glass in both of my tops were the same.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
So the glass is the same and the glass seals are the same also? I have read on here guys that say they are and some say they are not? How about the wiring harness from the fuse box to the single wall. Does anyone reproduce those?.......... Thank you guys for the input. I'm doing my first blazer restoration and I could have never have done it without this forum. You all have saved me so much money and time!
I have an extra single wall harness I will be placing in the for sale section soon. I will give you first dibs on it.
Chris Posted via Mobile Device |
Re: Need help with Single wall side glass.
Thank you Chris. I really appreciate the help, Josh
#8 | |
I am about to try this same thing. Just windering about some followup blueridge? How'd it work?
And bentblazer, I have double wall glass and gaskets to put in my single wall. Should I use the doublewall gasket or the single wall gaskets I have? Posted via Mobile Device
1967 SWB C-10 1972 Blazer 4x4 2011 Silverado |
If you can compare the two, I believe you will find they are the same, but if it were me I would use the the ones that were for the single wall.
Thanks I really appreciate your input bentblazer!
Wide n'Low
![]() Join Date: Jan 2007
I have seen a set from both a double wall and single wall side by side, the gaskets are different, and if I remember right, so was the glass I was looking at.
I think it was Livrat who has several samples of each and could possibly give us all a definitive answer.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#13 |
Yes, I remember seeing that. But apparently the differences aren't so major as to keep the switch from working, because I have seen quite a few say they did it no problem. I'll be trying it soon and will post how it goes!
#14 |
I have not tried putting glass in my single wall yet.....I'm still working on the body work. I have two double walls a half top and a great single wall. So I'm going to get them out soon and compaire. I'll let you know what I find. Thanks to all for the input!
#15 |
Wide n'Low
Update!! ** I found the original post that the pictures came from.. not surprised it's a board member.. http://67-72chevytrucks.com/vboard/s...d.php?t=252569
Ok, I hope this helps a bit, I finally found the pictures I had tucked away. I owe credit to the owner of these as they are not mine, but I can't seem to find the reference site I found them on.. Probably a board member ![]() Next will be to measure the glass thickness between the two styles and see what that is..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired Last edited by Twisted78SS; 09-27-2012 at 01:47 PM. |
