I need some info/favor about cranksensor
I am still trying to start my engine but have no spark. I had to add a cranksensor connector to my harness and don't know if I wired it correctly, the first time.The connector has A,B,C on it The way I wired it in is A to lt/grn blue pin #2, B to yel/blk blue pin #21 and C to blu/wht stripe, blu pin #12.
Can someone tell me if this is wrong or right? |
Re: I need some info/favor about cranksensor
No one? I think I found the answer I will try and test them tonite.
What year harness? 2001 is C goes to 2, A goes to 12 and B goes to 21. So you may have a couple reversed.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
It was reversed c&a so I swapped them and still no spark, I tested the cranksensor and it seems bad. I will try another sensor tonite.
