Old 05-31-2012, 02:23 PM   #1
BLUE SQUARE
BLUE SQUARE's Avatar
Need Advise - Do I need a C Notch
I will be lowing my 87 swb 5/7 or 5/6 based on which hole I use in the shackle. I will be buying a Western Chassis Flip Kit and keeping a full spring pack. Then adding the 2" shackles. I've read a couple of members threads where they did not use the C Notch (BiggArmz is one). My truck has a towing package and I may have to tow a vehicle once in a great while. I'm just not sure if a Notch is absolutely necessary. Will just removing the bumb stops give me enough clearance to load or tow anything? Please let me know your experience with this.
BLUE SQUARE is offline   Reply With Quote
Old 05-31-2012, 02:42 PM   #2
school boy
school boy's Avatar
Re: Need Advise - Do I need a C Notch
definately remove the bump stops, the axle will be very close to these still in place. with my 7 inch rear drop, i have 3.5 to 4 inches from axle to frame and a 250 lb person can jump up and down on the bump and get it to hit. granted i only have the 3 leaf pack too. im going to install the helper bags on mine to hual anything heavy or pull a trailer.
school boy is offline   Reply With Quote
Old 05-31-2012, 09:10 PM   #3
Rich84
Rich84's Avatar
I think anything more then a flip kit will require a c notch.. But if you have a thick leaf pack it will drop you 6-7 inches.
Rich84 is offline   Reply With Quote
Old 05-31-2012, 09:11 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Yes.
C-notch required.
Keith
Convert to disc brakes.
Old 05-31-2012, 10:05 PM   #5
BLUE SQUARE
Thanks Keith-
I didn't want to take the bed off more that once. I want to freshin things up while I have the bed off, so I will notch it at the same time. Hopefully, I can still tow a car if needed with the notch.
Old 05-31-2012, 10:07 PM   #6
lolife99
lolife99's Avatar
These 73-87 trucks had 2 different length leaf springs.
Some were 52".
Some were 56".
One of those will require you to notch a bed support also.
(to clear the 2" drop shackle)
I can't remember which length it was.
Keith
Old 05-31-2012, 11:51 PM   #7
BLUE SQUARE
I think I'm ok. I actually have 2 inch shackles on it now with no problems. It was sitting real high stock and I had some laying around, so I just slapped em on. That's a great point though. Thanks for the heads up. I like your truck. Those are hard to find in good shape.
Old 06-01-2012, 03:45 AM   #8
Square_78
Square_78's Avatar
heres mine at ride height in the back or maybe a little higher. I was just hauling my big dirt bike around so I had some more air in the back shocks. Theres a good 3" of space before the axle hits the bumpstops. With all the air out of the back, its an 8" drop and no c-notch. Right now its about 6" lowered in the back and it wont bottom out unless you have 300lbs in the bed and hit a big bump. The only reason I;m going to c-notch it is because I am adding 2.5" drop spindles and 2" lowering blocks in the rear over the winter. Then I will be running 7.5/10 drop. Will probably have to bag the front after I do that
Square_78 is offline   Reply With Quote
Old 06-01-2012, 02:43 PM   #9
BLUE SQUARE
Great info Square_78. Thanks, how do you like those air shocks? I wonder if I can get away with just adding air shocks and if I could tow with them.
I will most likely just notch my frame and be done with mine. I think 6" to 7" is the lowest I will go in the back depending on the rake I get after I drop the fron 5" with 2.5 srings and 2.5 spindles from western chassis. Hopefully the 2.5 spindles don't cause my 15x8 rallies to rub.
Old 06-01-2012, 05:21 PM   #10
Square_78
Square_78's Avatar
I love the air shocks. I dont know if they are designed for towing or not. But they work great when you need a little extra lift for a heavier load.
Old 06-01-2012, 10:04 PM   #11
bigblock73
yeller
bigblock73's Avatar
The shorter springs require the cross sill under the bed to be notched when running drop shackels
bigblock73 is offline   Reply With Quote
