I miss this truck.
Shock absorber recomendations
Anybody got any good or bad experiences with shocks for a '70 C-10 coil spring truck? I see RockAuto has a Monroe for $10/wheel. I like the idea of being able to change all 4 shocks for $65 shipped, but don't want to get crappy ride and handling out of the deal.
Further info, the truck is my daily driver. Stock ride height. Rarely tow with it, and only haul anything heavy a couple times a year. BTW, they've also got Moog rear coil springs for $75 a set + shipping.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. Last edited by Tynee; 05-31-2012 at 03:45 PM. |
Re: Shock absorber recomendations
I am interested in some recommendations on this topic also. I think I am due for a set of shocks.
1968 C10 LWB Tulsa, OK |
20' Daredevil (Ret)
![]() Join Date: May 2003
I've had excellent service from KYB Gas-A-Just shocks which contrary to their name, are not adjustable. They are a bit firmer than OEM and have great rebound control. The ride will soften up a tad with use but they retain good control (they don't get mushy). And they're reasonably priced for a high-quality shock, but you won't get them for $10 each. In fact, at that price you probably won't be happy and they won't last long. I remember buying cheap shocks from Sears once and I returned them -- they were very soft & floaty.
I have also heard good stuff about Monroe Sensa-Tracs.... I just haven't owned them.
I have not yet put on new shocks, but I contacted KYB tech support and their answer is toward the end of this link; this is how I plan to go--hope this helps:
http://67-72chevytrucks.com/vboard/s...d.php?t=475916 |
Kyb will be the way to go they are more money but well worth it in my book
Justin |
I put on a set of NAPA branded shocks a few years ago, the ride improved, but its still bouncy. I'm sure I need to replace the 40 year old springs though. I have used KYB with my wife's cougar and am very pleased with them. Their customer service is very good also.
![]() ![]() 71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
Registered Cruiser
About twelve years ago I bought some Gabriel gas shocks from AZ. I think they were about twenty five, or thirty dollars each at the time. Decent shocks, but the best part is whenever they start to feel worn, I get them replaced for free on the lifetime warranty.
I intend to live forever. So far, so good. |
I miss this truck.
Thanks for the input, guys.
RegularGuy, I'm not sure why my search didn't turn up your thread.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
![]() Join Date: Nov 2007
I put KYB gr-2s on my K20 and real happy with them. Had the regular Gas-adjusts on the rear of my chevelle and they were a bit too firm, and many said the same about the ride on their trucks.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#10 | |
The guy said their recommended OE replacement for a '70 rear with coil springs is KG5416 Gas-A-Just, because the coils do not support as much weight as a leaf spring set up. The Gas-A-Just has a damping rate close to the original, and is about 10% firmer than the GR-2 (the GR-2 has been renamed "Excel G" and is painted black, but is otherwise the same shock. Just a name and color change). So, a slightly stronger shock is desired. He said there will not be a difference in ride quality or characteristics if we choose to put Excel G's on the front and Gas-A-Justs on the rear... |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Bilsteins are available for our trucks too.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
