Old 05-31-2012, 09:02 PM   #1
melon8657
Fuel Tank Conversion, no fuel to carb
Over the weekend I installed the underbed fuel tank conversion on my 1969 c10 (Longbed) from LMC. We have put around 7gal of gas in fuel tank, gauge is actually reading 1/4tank but I am not getting anything at the carb. I have about 1.5ft - 2ft of rubber line from fuel tank to 4ft of metal line, then 6inches of rubber, fuel filter, 4inches of rubber then factory metal to the mechanical fuel pump, metal from fuel pump to carb. Last night I blew through factory metal lines with air compressor to make sure they weren't plugged up. Tonight I replaced mechanical fuel pump, and back blew from fuel filter to tank. Still not getting any gas to the carb.
What am I missing? Is there to much distance from mechanical fuel pump to the new fuel tank? Do I need to install an electric fuel pump close to the tank?
melon8657 is offline   Reply With Quote
Old 05-31-2012, 09:33 PM   #2
midniteblues
midniteblues's Avatar
Re: Fuel Tank Conversion, no fuel to carb
I had a problem priming a new tank,and line install once,
I disconnected the fuel "in" line at the pump and put a bucket under it then cupped my hand over the fuel filler an used the air threw my cupped hand the pressure pushed the fuel though the line I heard it runnig out and then
I quickly reconnected the fuel line and cranked it a little then it started fine.
I thought I was going crazy not getting any fuel up to the carb oh an I killed the battery trying too
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-01-2012, 02:41 PM   #3
sharpmark
a mechanical fuel pump in good condition should pump fine from the tank as long as air doesn't get in.just done this on my truck.make sure all rubber to pipe connections are good!
couple of things to try-when you blow back thru the lines into the tank- can you hear the fuel bubbling? if so that will tell you the fuel pickup pipe is under the fuel level.if not then your pickup pipe has a problem.
another way to try is to block off the vent pipes in the tank and remove the first length of rubber from the 4ft of metal pipe and then put a rag around your air gun and pump some air into the filler pipe-fuel should come out of the rubber hose.WARNING donot put much air in or you could balloon your tank or squirt fuel everywhere.
if this works then you have to work your way down your delivery line looking for the problem.
good luck
mark
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 06-06-2012, 08:04 AM   #4
melon8657
Thanks for the replies, I did get it going last night. After reading replies about possible air in lines I used a Mini-Vac system we have for bleeding brake lines and a pair of hemostats. I disconnected rubber line from fuel pump and hooked Mini-vac up to the metal line there, then using hemostats crimped off rubber line by the fuel filter (this way I could see gas coming through filter if it was working). After about to cycles of doing this the pint container on the mini-vac was full of fresh gas. I then disconnected mini-vac, hooked up the the rubber and metal lines by the fuel pump, and disconnected the fuel line from carb. After fuel line at carb was disconnected I poured gas from mini-vac container into the line that runs from fuel pump to carb, reinstalled line and she started without any hesitation. Thanks for the input.
Old 06-18-2012, 08:53 AM   #5
melon8657
still having problems getting fuel to carb. Since the truck is at my in-laws, which is 20 miles away and chasing my kids around with soccer, softball, and cheerleading it has been 2 weeks since I was able to get back to it. This weekend I had no fuel to carb AGAIN, had to do the same routine I did last time. Checked under truck and there are no fuel leaks and all hose clamps are tight. Wondering if electric fuel pump is the way to go??!!
Old 06-18-2012, 02:58 PM   #6
Tynee
I miss this truck.
Tynee's Avatar
In my experience, no. They are noisy and unreliable. I've never been so happy to finish a project as I was the day I converted mine back from electric to factory mechanical. I don't have the tank under the bed, it's still behind the seat, but I would suggest doing everything else you can do BEFORE you add an electric fuel pump to the syste.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 06-18-2012, 03:05 PM   #7
mrein3
mrein3's Avatar
In this situation I always "prime the pump" by pouring a little gas in the carb then turning the key. My theory is that the engine firing and spitting on that gas I poured down the carb works the fuel pump WAY more than just turning the pump with the starter motor. Not only do you need to fill the fuel lines but you also have to fill the carb bowl(s).
Just be careful. A little gas down the carb goes a long way.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-18-2012, 05:59 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
What mrein3 said...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-18-2012, 06:54 PM   #9
melon8657
Thanks everyone, I will hopefully get to try that extra bit of adding fuel directly to the carb on Wednesday.
Old 06-18-2012, 07:15 PM   #10
SS Tim
SS Tim's Avatar
If it didn't have enough gas left in the lines and the carb bowls after running normally then sitting about two weeks I'd say there are leaks in the system allowing the fuel to siphon back into the now lower tank. Also to back fill a line, a bowl or prime a long sitting engine I've found a restuarant ketchup style squeeze bottle with the tapered capable end works great.
SS Tim is offline   Reply With Quote
