Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-31-2012, 09:06 PM   #1
paulspickupparts
63-66 Chevy GMC Fleetside Rear Bumper With Brackets and Pans
I removed this 63-66 Chevy GMC Fleetside Rear Bumper I am parting out. It is a 63 Chevy Custom Cab truck so was kind of loaded up with accessories. This would be for the guy who wants a real GM rear bumper. Real GM brackets. Real GM splash pans. Please look at the images as this is a used bumper and will need to be replated for show. Previous owner drilled a hole for a ball hitch. Bottom of bumper has a small notch wore into it from and under the bumper hitch which could be ground smooth. Chrome shop can easily fill. The bumper has surface scratches and the two center holes have a slight pull. One filler pan will have to be straightened. Brackets are nice and straight but of course will need to be repainted. Brackets may have to be removed for shipping so no guarantee if the original bolts will unthread . This is for the person that wants a real GM bumper made of spring steel and original look. The repos are only a click away. I also have the front in another thread. Price on this bumper with brackets $175 plus shipping (estimate $50-$75 but will be actual). ThanksBumper has been sold locally. Thanks for all the interest. Front is still available, Paul
paulspickupparts is offline   Reply With Quote
Old 06-01-2012, 02:57 AM   #2
Slow Build
Slow Build's Avatar
Re: 63-66 Chevy GMC Fleetside Rear Bumper With Brackets and Pans
Could you post some close up pictures of the rough spots?
If you could find out the shipping charge to 94531 I'd appreciate it.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-01-2012, 08:34 AM   #3
paulspickupparts
Sure, can you give me a Zip Code and if Greyhound would be an option at your location. Will try to post some pics in the next hour or so.
Old 06-01-2012, 10:13 AM   #4
paulspickupparts
Here are some pics of the front I circled two very slight dings pushing out . Bottom bolt holes slight pulled . Scuffing and scratches in the chrome. Maybe I should have said these are core bumpers. If you have a higher end daily driver they are probably not what you want. But if you want a good bumper that could easily be straightened(press) and rechromed later this would be a good bumper. Sorry I missed you zip. A rough estimate of shipping the front would be $55.66. It helps if you have a friend that has a business. Rate would be a little less.
Old 06-01-2012, 10:26 AM   #5
paulspickupparts
Here are the pics of the rear. Nice brackets and pan will straighten easily. Extra ball hitch hole . Liscense plates are slight rounded as previous owner bolted hitch on to this . At least he did not drill different holes . Bottom edge has worn area where hitch rubbed and created a step will not be seen but could be ground smooth before chroming. Some dings on the face where he backed up to hook things up. Nebraska Farmer! . Bolt holes have very slight pull and easily straightened. Few small bends at the bottom of the bumper in the middle . Would straighten easily. I have taken the brackets off and could include with front bumper as there will be more room in that box because of the curved bumper ends. Shipping would probably be the same in that $55-$60 range.
Old 06-01-2012, 11:23 AM   #6
Slow Build
Slow Build's Avatar
I'm interested in the rear bumper, not the front. The Stockton, Ca Greyhound station is the closest location.
Past GM Trucks:
Old 06-01-2012, 10:12 PM   #7
paulspickupparts
Greyhound shipping would be $77.75 . I would ship to your door via Fed X for $60. If more than that I will pick up the cost. Bumper would be taken apart and brackets and pans tucked inside the bumper. If I can ship to a business it might be less. Thanks Paul
Old 06-02-2012, 02:18 AM   #8
Slow Build
Slow Build's Avatar
I think I'm going to pass.
Past GM Trucks:
Old 06-09-2012, 08:39 PM   #9
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
How much Shipped to 91340
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 06-09-2012, 08:46 PM   #10
paulspickupparts
Will ship for $50 . Actual shipping may be a little more, if it is I willl pay the diff. Thanks
Old 06-11-2012, 10:38 AM   #11
ChevyFreak60
ChevyFreak60's Avatar
Is the rear bumper still available? And how much shipped to 87506
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 06-11-2012, 10:53 AM   #12
paulspickupparts
It is still available. I would ship it (dissassembled) for $50 to your door. Thanks Paul
Old 06-12-2012, 08:25 PM   #13
yelmer
hello would you sell just the rear brackets?
yelmer is offline   Reply With Quote
Old 06-12-2012, 09:29 PM   #14
Leadfoot Lambert
Leadfoot Lambert's Avatar
If you decide to break it up I would like first dibbs on just the splash pans, PM me if you do.
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 06-12-2012, 11:29 PM   #15
paulspickupparts
Well , if I can find someone who wants the bumper only I will split. I was going to throw on ebay and see if I can sell the whole thing. Will let you guys know if I split. You will be in line. Thanks
Old 06-16-2012, 10:05 AM   #16
paulspickupparts
Rear bumper has been sold locally . Thanks for all the interest. The front is still available .
