Old 06-01-2012, 01:30 AM   #1
GRIMACE 65
best spot to buy a lowering kit?
Where's the best place to get a lowering kit for my 65 burban? I've checked lmc , Orange county truck shop and CPP. Iwant to go as low as I can without buying spindles most likely a 3/4 . I wanna get the best bang for my buck
GRIMACE 65 is offline   Reply With Quote
Old 06-01-2012, 01:48 AM   #2
Pro Performance
Pro Performance's Avatar
Re: best spot to buy a lowering kit?
I would suggest Pro Performance!
Give us a call and we can go over your options as for lowering your suburban. You might be able to use the Hotchkis 4" drop coil up front, which will get you down pretty low in front.
If I may ask, how come you want to avoid a drop spindle in front? Is it due to budget? Only because, the drop spindle will be the best way without sacrificing ride quality and your front end geometry.
Pro Performance is offline   Reply With Quote
Old 06-01-2012, 07:30 AM   #3
scottofksu
scottofksu's Avatar
X2
Why not go 2" drop spindle and 1" drop spring? I know the spindles are more expensive than the springs, but I think you'll be much happier with how it rides. Personally, I'm getting the drop spindle; saving some more $ and then getting the spring. It'd be much more expensive to spend $100+ on 3" drop springs only to have to replace them when you find that it rides way to harsh and exhibits a high degree of under-steer in the corners. Just my to cents! )
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
