06-01-2012, 04:34 PM | #1 | |
Conversion Truck Addicted
Gas fuse box/cab wiring and Diesel engine harness
are the fuse block the same for the gas trucks as the diesel?
the orginal fuse box was melted and i havent been able to find one from a diesel in good condtion so i have a gas one but will that work ? as far i can see most of it is only power wires thats from fuses that contects to it the rest of the harnes goes through other harnesses
Thomas Quote:
06-01-2012, 07:46 PM | #2 | |
Moderator
Re: Gas fuse box/cab wiring and Diesel engine harness
Are any harnesses on the engine compartment side damaged? Do you know what caused the meltdown? Make sure you find it and fix the problem especially if it's not in the wiring you're replacing. You don't want to have a bad day later. The Fusible link should prevent this type of catastrophe. Make sure "that guy" didn't replace it with straight wire. If the panel is melted how much of the harness is affected? Depending on the extent of the damage you could mix a replacement gasoline cab harness with the existing diesel harness to make your rig complete.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-02-2012, 04:44 AM | #3 | |
it the fuse block that was melted in the fuse holders and the wiring was hacked
Thomas Quote:
