06-01-2012, 06:27 PM | #1 |
window felt
HI Guys
Has anyone replaced the window felt on the wing window? Is there a trick to it. I tried squeezeing it together with a pair of vice gripes and pulling it seems like the whole track whats to pull out (the metal around the felt) I don't want to force it and ruin something.Is it glued in? Thanks Buz48 |
06-01-2012, 07:07 PM | #2 |
Re: window felt
I have seen some that were glued in. I use a bent screw driver to assisit in getting the liner out.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-01-2012, 10:39 PM | #3 |
Re: window felt
That's the rub isn't it. Hard to get the rubbers in the frame. Welcome to the vent window refurb club. It will go in, just be patient. The vent window rubber is not glued in. If you really mean the divider bar felt, it can be glued in. The vent window rubber is just squeezed into the frame.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
