![]() Join Date: Aug 2010
What goes on my firewall? Pictures included
I picked up a replacement cab and am confused by the holes for the master cylinder. It looks like it has a dual master cylinder hole in it? Is there an adapter plate to run power brakes with this type firewall? Also on the roof where is the two tone cut off on the 60-63 cabs at the base of the windshield? Thanks guys.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
Re: What goes on my firewall? Pictures included
The two holes are for brake and clutch master cylinders. I believe Captain Fab makes brackets for power brakes that mount to that firewall.
Posted via Mobile Device |
Senior Enthusiast
Yes it's a 60-62 cab designed for the dual brake/clutch master cylinder. The 63 firewall is different having the mechanical clutch, and I believe the square lower heater opening is also different. As best I know the 60-62 has a cover with 4 retaining screws, while the later cover only uses 3.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Thanks guys for the help. Now to find that bracket. Also, will the heater from a 63 GMC work on this cab or is it different like you said from 60-62?
Just saw you guys are both from WA. Just left there in April. Was working on JBLM near Tacoma for about 7 months before taking my current job. I loved that place. I have lived all over the place but, Washington is by far one place I would not mind calling home. Rain and all!
and yes, the colors change at the bottom of windshield (belt line). There's a small step there, however, I have seen them with just the roof a different color (above the drip rails).... Not sure if this is factory tho.
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
koda360 I have seen them both ways as well and just was not sure exactly what way to go.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes, if you are wanting to put power brakes on that cab I have one for use with an auto trans and one for use with a manual trans. There are links to the for sale threads in my signature line below \/ \/ \/
Send me a PM if you are interested.
62 gmc burb
![]() Join Date: Mar 2011
My 60 has the same square hole for the heater. I sold the engine bay portion years ago but I think I have the inside the cab portion of thrust work still. The heater box is pretty much the same, it's the heater core that changes on OEM but the are generic ones available.
http://67-72chevytrucks.com/vboard/s...d.php?t=456437 |
