Front end lift suggestions
Any suggestions would be helpful. 71 GMC C20 front coil springs with a 350. I would like to raise my front end approx 2 to 3". Should i try a spacer, larger springs or what?????
Re: Front end lift suggestions
These two threads may help you. The front ends are real similar through the years.
http://67-72chevytrucks.com/vboard/s...d.php?t=442205 http://67-72chevytrucks.com/vboard/s...d.php?t=469743
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
