a little help
I have a 1987 chevy silverado c20. While drivng today my turn signals quit working. I believe its a bad fuse. However i dont have a manual and I"m not sure which fuse it is. Does anyone know or have a picture to show me. Thanks Mike
Posted via Mobile Device |
Re: a little help
I'd just pull each fuse one at a time and check it until I come across the one that is blown. It's a PITA to do, but sometimes you might find more than one fuse that needs to be replaced. I had to do that on my camaro once because the labels for the fuses had worn off.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
Re: a little help
Thanks....i found it on the 3rd on.
