Old 06-02-2012, 08:18 PM   #1
TheApocalyptican
TheApocalyptican's Avatar
Fuse Box Help
Need some help with my fuse box. I need to know what supplies the circled section of the box with power. As it is reading too low, and I need to either splice in or replace a wire to get it to the correct voltage.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 06-02-2012, 09:24 PM   #2
TheApocalyptican
Re: Fuse Box Help
So I found the wire that I believe supplies this section. It's a 12(10?) gauge pink wire that goes to the ignition switch. Anyone have any idea how the ignition switch could be outputting less than batt voltage?
Old 06-02-2012, 09:55 PM   #3
hatzie
Moderator
hatzie's Avatar
Re: Fuse Box Help
If I read my 1989 GM diagrams correctly these are fed from the Ignition switch terminal IGN 1. It's Circuit #3. The A & W taps are protected by the IGN fuse.
There's a splice near the bottom of the steering column that connects The pink fuse panel and bulkhead wires to the ignition switch. I'd look there for a loose connection.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-02-2012, 10:03 PM   #4
Sabaka454
Sabaka454's Avatar
Re: Fuse Box Help
What is the voltage at IGN vs CTSY?
Sabaka454 is online now   Reply With Quote
Old 06-02-2012, 10:30 PM   #5
TheApocalyptican
Re: Fuse Box Help
I'll have to check that.
Depending on conditions ctsy is 12.8 to 13.8. IGN is 11.8 to 12.1 with the lower and higher numbers being corresponding with each other.
