Old 06-02-2012, 08:34 PM   #1
GMC Canuck
drop my '68
I keep looking at my truck and keep thinking it needs to be about 3" lower. The truck has it's original stock springs so they're probably a little sagged already. I have about 6" clearance front and back wheel well to top of tire. There is about the same clearance from axle to frame at the rear. How far down can I go before needing a c-notch? What drop do I need to keep it level? I was looking at coils front and rear and maybe blocks on the rear as well to keep it level. Besides coils, shocks and adjustable panhard bar is there any other surprises I should be aware of?
GMC Canuck is offline   Reply With Quote
Old 06-03-2012, 01:59 PM   #2
chevy406
chevy406's Avatar
Re: drop my '68
sorry i know this is off topic but what kind of mirrors are those?
chevy406 is offline   Reply With Quote
Old 06-03-2012, 08:49 PM   #3
GMC Canuck
Re: drop my '68
not 100% sure, but I think off a late 80's caprice. They were on the truck when I bought it.
Old 06-03-2012, 09:03 PM   #4
2002yanks
Re: drop my '68
you can get 2/4 3/4 or 3/5 on just springs/shocks. can go more on the front but you would need drop spindles.
2002yanks is offline   Reply With Quote
Old 06-03-2012, 09:04 PM   #5
Pro Performance
Pro Performance's Avatar
Re: drop my '68
I would suggest a 4.5/5" drop with c-notch, but if you you want to stay clear of doing a c-notch, then a 2.5/3 is what I would recommend. It won't get the truck sitting right on the tires, but would give it a better stance and help close the gaps.
Pro Performance is offline   Reply With Quote
Old 06-04-2012, 10:44 AM   #6
Scottshotrods
Re: drop my '68
Here are the parts I would run on your truck
1.Front dropped spindals 2 1/2 Cpp
2.Dropped springs 2 inch Cpp
3.Dropped shock kit Cpp
Rear of your truck
1.5 inch dropped springs Cpp
2.Dropped shock kit Cpp
3.Bolt in c-notch Cpp
4.Rear pan hard bar Cpp
We have these parts in stock from Cpp and have some great prices on these items.If you are intrested let us know you can p/m us or e-mail or call us
justin@scottshotrods.com
scotts@scottshotrds.com
(805)485-0382
Justin
Scottshotrods is offline   Reply With Quote
Old 06-11-2012, 02:12 PM   #7
GMC Canuck
Re: drop my '68
So I settled on a 3/4 drop. 3" drop spindles and 4" coil on the rear.
it still sits nice and level, looks fantastic and handles even better as long as I don't need to go around corners. Apparently there are some clearance issues with a 3" drop spindle and a 15" rim.
not sure what I'm going to do now. Maybe a tubular lower control arm will give a little more clearance, possible switching the 3" spindle to a 2" with a 1" coil. Maybe I can do a little adjustment to the existing lower control arm. I haven't had a real good look yet. There is a little voice in the back of my head that keeps saying, if you switch to a larger wheel, problem solved and you can get some larger brakes too. But I really like my wheels.
Old 06-11-2012, 02:25 PM   #8
Pro Performance
Re: drop my '68
Looks great!
