06-02-2012, 08:43 PM | #1 |
1972 front suspension
Hey guys I need all the help/advice I can get! I am replaceing the upr and lwr cross shafts,upr and lwr ball joints,inner and outer tie rods, idler link, pittmen arm and coil springs. Any pictures and advice I can get would help. Thanks Alex
06-02-2012, 10:06 PM | #2 |
Re: 1972 front suspension
a bfh (big f'n hammer) and some wd-40.
or if you have access to a ball joint pickle fork.
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana instagram - @esso_c10 @projectpawpaw |
06-03-2012, 01:37 PM | #3 |
Make sure you get th drag link put back in the correct orientation. It's easy to get in back wards.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-03-2012, 01:52 PM | #4 |
I've got to replace an upper ball joint and cross shaft on my 71 3/4 ton this morning so I'll try to take a few photos.
I agree with Orngsikl (had to read that twice) in that a bfh is your best friend here. |
06-06-2012, 01:47 PM | #5 |
Just a nother gear head
Do one side at a time. that way if you forget how it goes, you can still look at the other side. then leave center link and idler for last once you have arms and splindles back on.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
06-06-2012, 04:03 PM | #6 |
Thanks for the info guys. I am having a problem with the outer tie rod right now. Seems the cone bolt that fits into the spindle is too short I can't get the cotterpin hole. I got the tie rod from lmc and I am going to NAPA today and see what they have.
06-06-2012, 04:50 PM | #7 |
I got my cross shafts and everything else that I can off of Amazon. I personally like MOOG better than other brands and they are a fraction of the price on Amazon as they are at NAPA for the very same parts. NAPA was asking 64 dollars for one single cross shaft (the smaller one even) and from Amazon 26 bucks, no tax and no shipping! And be sure you grease them well. Otherwise they turn to rusted dust a lot sooner.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
