Old 06-02-2012, 11:40 PM   #1
chebyshortbox65
chebyshortbox65's Avatar
12 bolt
Anyone know if the 4*4 6 lug 12 bolts use the same gearset and carrier as the 5 lug 12 bolt.I've got a 3.08 and looking for 3.42-3:73 looks like there were more options in
4*4 I'm running a 5.3 and swaping the 350c to a 700r4 and not sure how the 3:08 are going to work out
chebyshortbox65 is offline   Reply With Quote
Old 06-03-2012, 08:08 AM   #2
80SPORT
80SPORT's Avatar
Re: 12 bolt
all the truck 12 bolt gear sets should interchange ......
80SPORT is offline   Reply With Quote
Old 06-03-2012, 09:51 AM   #3
ont_guy_38
ont_guy_38's Avatar
Re: 12 bolt
^^ yes
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 06-03-2012, 10:21 AM   #4
Firebirdjones
Re: 12 bolt
The truck 12 bolt gears will interchange,,,,but the carrier break is 3.42, so if you are running what is actually a 3.07 gear, anything more than 3.42 and you'll need the carrier to go with it,,,,unless you buy new thicker gear made for the 3.42 and down carrier.
You might find the 3.07's aren't bad. I run a 6.0/4L60E in my blazer and ran 3.07's for a while along with 33" tires. With the 3.06 first gear it still had get-up-and-go and would lay rubber. Not sure how your 5.3 is going to react however. You might need more gear with that engine.
I went 3.73's in mine not too long ago when I came accross another pair of housings. Definately a big difference in performance but it's not something I feel was necessary. It runs good either way.
Firebirdjones is offline   Reply With Quote
Old 06-03-2012, 11:55 AM   #5
chebyshortbox65
Re: 12 bolt
Thanks for the info guys I will have to try it out and see how see does
Old 06-03-2012, 09:59 PM   #6
shipma2
Re: 12 bolt
should interchange, 5 lug and 6 lug 12 bolts were pretty much the same aside from one lug
shipma2 is offline   Reply With Quote
