Old 05-14-2003, 04:41 PM   #1
TIMSPEED
TIMSPEED's Avatar
Will have a Posi over a Pegleg actually make me "faster"?
I'm thinking about taking my truck to the track to see what it'd run. Now, here's the thing, I could CARE LESS about what my E.T. is, all I'm concerned about is my MPH. With a 3.73 posi would my MPH be different, than having my 4.10 pegleg. (We're assuming same tires, no drag radials, just plain Kumho 255/55 17's)
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-14-2003, 04:45 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Yes.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-14-2003, 04:52 PM   #3
TIMSPEED
TIMSPEED's Avatar
How MUCH different? 1-2mph or like 3-5?
See Them Here
Old 05-14-2003, 08:38 PM   #4
1FaastC10
1FaastC10's Avatar
Tim, lets put it this way... the pegleg puts the power to the wheels with the least traction. a posi or LSD device will put the power to the one with the most traction. traction = forward movement. the more traction you can get, the faster it will be.
1FaastC10 is offline   Reply With Quote
Old 05-14-2003, 11:56 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Will have a Posi over a Pegleg actually make me "faster"?
Originally posted by TIMSPEED
... Now, here's the thing, I could CARE LESS about what my E.T. is, all I'm concerned about is my MPH. ...
I have to know WHY? If all your concerned about is mph, back up way behind the line and get a running start. I have never heard anyone say they don't care about e.t.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-15-2003, 12:10 AM   #6
ocbaud
Garage Queen Material
Re: Re: Will have a Posi over a Pegleg actually make me "faster"?
yeah, if he wants mph, he should jump on the highway with some 2.73 gears and a 700r4:p
ocbaud is offline   Reply With Quote
Old 05-15-2003, 03:12 PM   #7
rockman20
"The dude abides"
rockman20's Avatar
4.10 peg leg? That thing must just BBQ that rear tire!
Switching to posi will let you get out of the hole quicker since power is being sent to both wheels instead of just the one that spins the easiest. Even though you will be losing some gearing, I would say it should make you faster. Not sure by how much, but I live by what my old auto teacher told me once.
"Spinning your tires is not impressive. Anyone can create a cloud of tire smoke. But tire smoke does not make your car fast. If you think it does, I will make you a bet. 20 bucks says your car is not fast. How we determine this is I will get in the car with you and tape your 20 to the dash in front of me. You mash the gas and if I can not reach forward and get that 20 off the dash, then you have a fast car."
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 05-15-2003, 03:45 PM   #8
1FaastC10
1FaastC10's Avatar
a spool would put power to both wheels, any other traction device should just put it to the wheel with the most traction.
Old 05-15-2003, 03:50 PM   #9
TIMSPEED
TIMSPEED's Avatar
But:
Spool + Turns = SNAP!!
See Them Here
Old 05-15-2003, 04:08 PM   #10
1FaastC10
1FaastC10's Avatar
nah, not if you buy a good one. good luck finding one for your 12 bolt though.
Old 05-15-2003, 04:55 PM   #11
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
But:
Get a lockrite or power trax locker. It divides power to both wheels and comes unlocked when you turn. Plus you can install it yourself without resetting the gears.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 05-15-2003, 05:11 PM   #12
CT-Truckster
CT-Truckster's Avatar
only if you have enough power to make use of it.
CT-Truckster is offline   Reply With Quote
Old 05-15-2003, 05:16 PM   #13
rockman20
"The dude abides"
rockman20's Avatar
Sorry if I am naive here, but here is how I thought a posi worked. Inside it has a set of clutches inside. When you mash on the throttle, the spider gears push the axle side gears out which compresses the clutch plates and provides power to both rear wheels. Not just the one with traction.
However, to prove that it does not provide power to the tire with traction, you can get stuck with a posi unit. Stop with one tire on ice and one on pavement. There is not enough force on the spider gears to push outwards on the axle gears so in this case, the tire with less traction gets the power.
Never seen a spool but have a basic concept of a Detroit Locker Here you have kind of the same idea except for instead of clutches it is kind of like a collar assembly. Springs force the two collars together which basically locks the rear end solid. If you go to take a corner, as long as you are not applying lots of power to the assembly, the collars are able to overcome the spring pressure and they pull apart giving you an open rear end again.
I would never use a spool on the street. If you wanted to go that route, bring your truck over. I will weld your gears together and you will have the same effect.
But I could be wrong here.
RockMan
1994 Honda Civic
New to the fleet:
1992 Subaru Loyal
Old 05-15-2003, 05:19 PM   #14
TIMSPEED
TIMSPEED's Avatar
Actually, you're dead RIGHT. A lot of honda guys that ONLY drag race there cars, will weld their axles together, to get the ultimate traction for CHEAP.
See Them Here
Old 05-16-2003, 11:30 AM   #15
Captkaos
Captkaos's Avatar
A locking differential (detroit, lock-right..) LOCKS both axles together like a spool, UNTIL you turn and it "differentiate the power, or unlocks the inside wheel.
A limited slip has a set breakaway that both are locked until that breakaway torque is exceeded.
Spools AREN'T a differential, and are shouldn't be used on the street. Chevy rearend require a c-clip eliminator for their use, typically these aren't "approved" on a race track.
Reguardless, in actuality, locked or open isn't going to effect top speed as much as changing the gear ratio. It will effect your ET though. If you are talking about your ET top speed, then yeah it will change as you will be actually moving with a posi as opposed to spinning with an open. How much I don't care to guess as there are too many variables to consider, but if you swap from one to the other, you speed AND ET will change.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
