Old 06-03-2012, 04:56 PM   #1
klutz51
fram modifacatins
i want to use the stick fram for the v8, what modifactions do i need to streigthen the frame
klutz51 is offline   Reply With Quote
Old 06-03-2012, 06:20 PM   #2
Amorget
Re: fram modifacatins
Do you mean frame? Fram is a company that makes filters.
What is "the v8"? AD or TF?
Just to note, 95% of V-8 swaps don't need frame strengthening.
Amorget is offline   Reply With Quote
Old 06-03-2012, 07:29 PM   #3
klutz51
sorry frame not fram. first time at this and seeing if i need to do anything for a 350 engine and 700r4 trans, and a 10 bolt rear end.
Old 06-03-2012, 07:58 PM   #4
Amorget
The frame is plenty strong for that.
Old 06-04-2012, 10:17 AM   #5
98layinframe
98layinframe's Avatar
The stock frames flex/twist a ton.. boxing the rails and building a couple X shaped cross members under the cab will help alot.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 06-04-2012, 12:21 PM   #6
OrrieG
OrrieG's Avatar
Do not need it unless you start running big horsepower racing application. These trucks were designed to flex, tighten them up too much and you get a harsh ride and other things bending and cracking over time, especially if you start limiting suspension travel. Something has to give.
OrrieG is offline   Reply With Quote
