Old 06-03-2012, 10:18 PM   #1
k-nuts
k-nuts's Avatar
Brake Question
My friend (without internet) has a 69 GMC 2wd leaf spring rear, With drums up front. He bought a 72 Chevy Cheyenne 2wd parts truck with discs up front. . Question is what all can be used to convert the 69 to disc. Just swap spindles? Or change the whole a arm assembly over? Thanks.
k-nuts is offline   Reply With Quote
Old 06-03-2012, 10:22 PM   #2
cubber
Re: Brake Question
I think you can use the same a arms, but the ball joints are different.
cubber is offline   Reply With Quote
Old 06-03-2012, 11:12 PM   #3
k-nuts
k-nuts's Avatar
Re: Brake Question
I was thinking since he was going to rebuilt front end anyways it would be easiest to just swap everything over. A arms, spindles etc. what about the master cylinder? I guess he should use it too.
Thanks for the help and any other suggestions.
Old 06-03-2012, 11:19 PM   #4
manimal
manimal's Avatar
Re: Brake Question
C10,c20,c30????
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 06-09-2012, 03:42 PM   #5
k-nuts
k-nuts's Avatar
Re: Brake Question
Not sure. His truck is a 6 lug, 2wd, leafspring rear.
The donor '71 is a 5 lug, 2wd, coilspring rear.
He's not sure c10, 20, 30.
Old 06-10-2012, 01:50 AM   #6
3rdGen.c10
3rdGen.c10's Avatar
Re: Brake Question
the entire front crossmember will convert over to the 69 with drilling like two holes if im not mistaken. lowlife99 has a great right up on this conversion. but yes the whole front crossmember a-arms and all with mover over and as for the master cylinder i believe you would need the conversion bracket from captain fab or a year specific master from cpp or ece. hopefully this helps and hopefully i didnt miss inform you... someone back me up or tell me im dumb
1967 c10 stepside 6.0L 4L80E
3rdGen.c10 is offline   Reply With Quote
Old 06-10-2012, 02:04 AM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Brake Question
cut the frame and weld in the 72 in
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
