06-03-2012, 10:35 PM | #1 |
what did you do with inner back panel after removing tank?
I have a 72 and moved the tank under the back bed. I would like to see pictures of what others did. I am going to be putting in bucket seats and am curious if I should paint it or carpet etc? Any pictures would really be appreciated.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
06-03-2012, 10:38 PM | #2 |
Old member
Re: what did you do with inner back panel after removing tank?
I used it for speakers and amp stuff.
06-04-2012, 03:57 AM | #3 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-04-2012, 06:21 AM | #4 |
I haven't gottin that far on my project yet but I plan on using a vinyl floor so it's easer to clean. You can power wash it if you get froggy!
With the inner panel I plan on building on to it with a 2x2 wooden frame and fiber glassing over it. It's not hard at all, just takes a lot of cure time and hand sanding to give it the look you want. But by the time your done you can mount speakers in there or anything you want. Especially when you make it the way you want! Thats the best way to make your truck special and one of a kind. |
06-04-2012, 11:45 AM | #5 |
We used the original tank as a speaker box. Fit like a glove and sounds great!
Texas - Don't Let The Size Scare You! |
06-04-2012, 03:14 PM | #6 |
Old member
I'll have to say that is the first time I've seen that mod! Good job man.
06-06-2012, 03:00 PM | #7 |
I built A custom speaker box! 3 10's can you say BASS
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
06-06-2012, 08:20 PM | #8 |
This is a picture of my son's 69 GMC with carpet. The gas tank is still there but this will give you an idea of what carpet looks like with buckets.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
