Old 06-03-2012, 10:46 PM   #1
krazy_texan
krazy_texan's Avatar
3/4 ton axles in my 1/2 ton
So I'm thinking of upgrading my axles in my truck as I have 10 bolt axles with 2.73 gears I use my truck on a reg basis and soon putting a cabover camper in it and prob towing a boat with it found a pair of 78 3/4 ton axles with 4.10s on Craigslist $300 for the pair with springs and tires still attached not crazy about the 4.10s but sounds like a good deal to me would yall go for it
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 06-04-2012, 11:27 AM   #2
survivingalone
Re: 3/4 ton axles in my 1/2 ton
in a heartbeat. thats a steal! the 4.10s will help with towing a boat.
survivingalone is offline   Reply With Quote
Old 06-04-2012, 02:22 PM   #3
semperfi
Do it. My 77 1/2 short bed has 3/4 tons. Dana 60 up front and a corporate 14 bolt in back. just make sure everything is solid on them pinion an gear wise as well as the straps and bolts on the rear yolk if it's the corporate 14 bolt.
http://www.pirate4x4.com/tech/billav...oke/index.html
That will explain why. I'm running 4.10 and it's a good middle ground for the heavier axles and my 35s.
That and might as well convert it to disc brakes while your installing the rear if they are still drums.
semperfi is offline   Reply With Quote
Old 06-04-2012, 09:01 PM   #4
krazy_texan
I'm going to rebuild them with all new bearings and such before install if I buy them I have all proper tools to do it, I have rebuilt diffs at school so I think I can tackle this
Krazy Texan
1990 v1500 suburban
Old 06-04-2012, 09:39 PM   #5
ch2000
ch2000's Avatar
That is a deal! I just swapped a set with 4:10s under my K5 and I love them..
http://gamelstreetrods.com
ch2000 is offline   Reply With Quote
Old 06-05-2012, 01:17 AM   #6
Your41Plague12
Your41Plague12's Avatar
That's a steal, snag them before someone else does. You'll love them.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 06-05-2012, 04:17 PM   #7
chevy427big block
if your truck is newer then 81 youll have to move the spring perches on the rear end out an inch on each side just went throught this myself last fall
chevy427big block is offline   Reply With Quote
Old 06-05-2012, 05:03 PM   #8
krazy_texan
Thanks for the info my luck I would pull my old axles out before I realized that and my truck is a daily driver so I would have been sol
Krazy Texan
1990 v1500 suburban
Old 06-05-2012, 05:11 PM   #9
rollinhard
rollinhard's Avatar
The time when you need to move the spring perches is if the rear different is out of a 1 ton. The 3/4 ton front diff is the same as a halftone but with larger spindles and brakes. And of course eight bolt. The rear springs maybe longer than your halfton. So you may need to move the rear shackle mount back.
Curtis
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 06-06-2012, 12:24 AM   #10
86454k30
86454k30's Avatar
Those 78 axles will bolt directly in place of your 86. You will need new rear ubolts and the 3/4 ton top ubolt plates. You don't need to move spring pads on 3/4 ton to 1/2 ton only on 1 ton axles do you need to move spring pads.
You can run a conversion joint on the factory 86 driveline so you won't need driveline work.
86454k30 is offline   Reply With Quote
