Old 05-14-2003, 06:29 PM   #1
Tobes85K5
Question Flipped steering wheel
The steering wheel in my K5 is flipped. I attempted to rotate the linkage 180 degrees to no avail. Am I just a moron and missing something simple?
Tobes85K5 is offline   Reply With Quote
Old 05-14-2003, 06:47 PM   #2
rage'nrat638
rage'nrat638's Avatar
did you take loose at the box????or try to slip the spline joint????
rage'nrat638 is offline   Reply With Quote
Old 05-15-2003, 10:37 AM   #3
Tobes85K5
I did try to slip the slip the spline joint out and rotate, but I did not try to take it loose at the box. I guess I got too frustrated and overlooked that option. Thanks for the suggestion. I will give it a go this evening.
Old 05-15-2003, 05:25 PM   #4
ol84
T, make sure you get James to help you since I am not there, your mechanical knowledge is at best equal to a monkey j/k. Actually, I think this will work. Call me tonight if you need some help.
1984 C10 SWB
Custom Frame
Blow Through Carb Single Turbo
Hope to be on the road by Summer 2018
1967 C10 CST LWB
327/PG Original
Running Driving Future Project
ol84 is offline   Reply With Quote
